Diesel General Discussion This section is for general discussions about your Deisel RAM. Non tech related RAM threads belong here.
Cruise control issue.
Old 09-02-2014, 06:38 PM
Jakeldavis84's Avatar
Jakeldavis84
Jakeldavis84 is offline
Default Cruise control issue.
Ok, I've hunted and hunted and researched with no luck so far. Here goes. I have a 2006 ram 2500 cummins. My cruise control will not activate. It is not controlled by vacuum. It is all electrical. By using a snap Solus ultra computer I have found out why the cruise will not allow itself to activate. The cruise light comes on and is receiving commands but is ignoring them because it is being told that "brake switch #2" is being pressed. I replaced the brake switch behind the brake pedal because a dodge dealership told me brake switch 1 and 2 are in the same component but use different signal wires. Yes I replaced the switch correctly by installing it before I released the little lever. I have even replaced it a second time to make sure I did not get a faulty switch. Is the dealership telling me the wrong information about where "brake switch 2" is located or am I missing something. Thanks for any help.
Old 09-05-2014, 02:40 AM
horatio102's Avatar
horatio102
horatio102 is offline
If I remember and have time tomorrow, I'll pull up a schematic and see what your other possible issues are. Could be a shorted wire between the brake switch and wherever the wires go.
Old 09-05-2014, 06:57 AM
Jakeldavis84
That would be awesome. Any help is appreciated.
Quick Reply: Cruise control issue.
