brakes -hard pedal
RE: brakes -hard pedal
brakebooster is either shot.. or lost vaccuum.. check the big vaccuum hose coming off of brake booster (the master cylinder is attached to the brake booster.. looks like a canister type deal) make sure they arent broke or disconnected.. if they are ok.. unplug it.. start the engine.. if you put your finger on the hose and it sucks on your finger.. the vaccuum is good.. if not.. you need to find out why the vaccuum isnt working.. if vaccuum is present .. replace brake booster
on
1991 thru 1993 has the bendex 10 ABS, There is a 685 recall for the bendex abs system. And this is a lifetime recall. The reason the pedal is hard is because the ABS pump stop pumping. The recall only covers the ABS pump and the master assy. If there is any problems with the dual fuction switch or actualator ball are not covered.
