Have a 2001 Caravan with an intermittent problem: Starts fine, but wipers/radio/blower sometimes all go off. Sometimes they come on again without doing anything. Horn randomly honks without touching it.
I've jiggled the key around to see if it is ignition switch related but doesn't appear to be.
It gets a little more interesting; Sometimes if I turn the wipers on they will work but radio/blower will go out while the wipers are moving. Sometimes the radio and blower will go back on for a split second while the wipers are in the "rest" position with the wiper switch in the Intermittent positions.
Checked fuses and swapped relays around - no improvement. Also ran an extra ground wire from battery negative connector to frame in case it may have been some sort of floating ground. No change.
As of yesterday, the blower only works on High. (Anyone know where the blower resistor is located so I can check that out?)
Thank you!
Adrian
2001 Caravan with 130,000 Miles almost completely trouble free (except above for last 2 weeks!)
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad. Click here to register for free!
