timing cover coolant leak - how hard to fix?
Old 12-23-2010, 07:25 AM
David Stembridge's Avatar
David Stembridge
David Stembridge is offline
Originally Posted by hemi4spd
i can get whatever picture u want,
still need them?
Yes, that would be helpful; although, I may not be able to start this till just after Christmas.... unless I can get out there a little this afternoon, and a little tomorrow. Thanks for the offer!
Old 12-23-2010, 08:16 AM
jumpdrive2's Avatar
jumpdrive2
jumpdrive2 is offline
Default 00 GC 3.3 timing cover
Old 12-23-2010, 08:33 AM
David Stembridge
Thank you jumpdrive2!!!!
Old 12-24-2010, 02:37 AM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
now thats good info right there!
Old 12-24-2010, 09:48 AM
David Stembridge
Does the Camshaft Pulley Puller have to be a Dodge specific puller? I tried using one last night that was too long.
Thanks!
Old 12-24-2010, 04:01 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
No, just a 3 jaw puller.
Old 12-24-2010, 05:07 PM
David Stembridge
Once the timing chain cover is off;
Is there something I need to look at that may help me determine if I need more than just a gasket?
I'm attaching a couple of photos.
Thank you for everyone that has offered a little advise on this!
Attached Thumbnails timing cover coolant leak - how hard to fix?-img_20101224_161421.jpg   timing cover coolant leak - how hard to fix?-img_20101224_161602.jpg
Old 12-24-2010, 07:27 PM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
just clean it up good to go (when its clean u can look for any cracks)
a decent scraper and a smooth hand to remove all the old gasket material.
parts stores carry this stuff http://www.permatex.com/products/Aut...et_Remover.htm
will get any stubborn gasket off. take care not to gouge the sealing surfaces
and before you mount new gaskets or any sealants cleanm sea;ing surfaces again surface with some acetone or laquer thinner (will ensure a good adhesion)
also while your in there you may want to do the waterpump(although its not hard job to do so I myself wouldn't do do it, cuz im cheap lol)
Old 12-24-2010, 09:26 PM
David Stembridge
Thanks hemi4spd,
a friend mentioned checking the seal once the cover was off, because that may have contributed to the gasket blowing.... looks like a worn gasket to me though!
What da ya think?
Old 12-25-2010, 12:06 AM
hemi4spd's Avatar
hemi4spd
hemi4spd is offline
seal? u mean crank seal?
looks to me from ur pics a new cover gasket will do the trick
Quick Reply: timing cover coolant leak - how hard to fix?
