2001 heater control valve
Old 08-17-2011, 10:14 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
the arrow follows coolant flow.
2 is the front heater core, 3 is the engine and 4 is the thermostat
Old 09-16-2011, 05:53 PM
Dlee's Avatar
Dlee
Dlee is offline
what is 5 and 6 then if you dont mind
Old 09-17-2011, 09:59 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
1 = heater core, rear
2 = heater core, front
3 = engine
4 = thermostat
5 = engine oil cooler (optional equipment)
6 = water pump
7 = radiator
8 = coolant recovery bottle
9 = coolant flow, pressure cap vacuum
10= coolant flow, pressure cap relief
Old 12-13-2011, 08:53 PM
Stenosis's Avatar
Stenosis
Stenosis is offline
Default Down
Just another confirmation...arrow points down.
What is the point of this valve?
Bless you guys for this forum!
-Sten
Old 12-21-2011, 08:09 PM
rmayes's Avatar
rmayes
rmayes is offline
Think of a merge lane on an interstate.
If the constrictor isn't there, the water cannot circulate from the rear heater core into the main line. The constriction in the valve speeds up the coolant allowing it to leave/enter the main line. Without it you would get little to any hot water to the rear heater core.
-Sten
Quick Reply: 2001 heater control valve
