2006 Caravan Horn
Old 05-19-2011, 07:39 PM
tcoles's Avatar
tcoles
tcoles is offline
Default 2006 Caravan Horn
The horn in my 2006 Caravan does not work. I checked the fuse it was good. Can any one help
Old 05-20-2011, 10:07 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Welcome to DF
Is the air bag lite on? The best way to check the horn, is find it first and then use a jumper wire from the battery to the wire that plug onto the horn. Does it blow? If it does, the horn is okay.
Old 05-21-2011, 10:14 AM
Tizzy1's Avatar
Tizzy1
Tizzy1 is offline
Switch is an input to the FCM and the FCM activates the relay to blow the horn. See if the relay clicks when you hit the horn button
Quick Reply: 2006 Caravan Horn
