[4th Gen : 01-07]: Pacifica question for Dodge/Chrysler experts
Hi all
I know this is a Didge site but there must be many Dodge/Chrysler/Plymuth mechanics out there that might be able to help!
I believe my Transmission is the same as that used on the Dodge Caravan.
Can anyone answer the following. I have an 04 Pacifica AWD with a broken transmission. Have a source for cheap (but fully functional) FWD transmission. Is it possible to simply remove the cover plate on the FWD transmission and bolt on my PTO/Converter assembly to allow my prop to connect? - or is there more to it than that.
It looks like it should work, but don't know if there are any additional bits inside the box that would be needed to make the conversion.
Any help or info would be much appreciated.
BTW - I also have a 2003 Dodge GC which is why I am a member of this site
Thanks in advance for any comments.
Regards to all
Gareth
Regards to all
Gareth
Hi Master Tech
Thanks for your reply and interest. Not sure I was clear in my question - both transmissions are Pacifica transmissions - the one in the car is AWD - the one I can get hold of is FWD - would have thought the bell housings were the same. Did you think I was suggesting replacing with a Dodge Caravan transmission?
Thanks again for your help.
Gareth
Gareth
That's very good news - this has been a huge undertaking for a home enthusiast and I didn't want to go to all the trouble of re-installing the engine and transmission - only to find it wouldn't work. Will replace o-ring (and all the other hard to get to parts) before re-installing.
Regards
Gareth
Regards
Gareth
