[4th Gen : 01-07]: Need Help W/Parking Brake / Rear Drums
Well I just created some new four letter words in changing the parking break pedal assembly without the results I anticipated.
Before = Very little brake to none when the parking break is applied.
After = Same
I did the installation and reset afterwards according to the service manual.
With the van in the air and the pedal applied the drivers side has a little and the passenger side has none.
Before I pulled the drum off I got under there with the P-Brake applied and the short (drivers side) was tight and the other loose enough I could pull it some. Very little.
I am looking at the breaks with the drums off now and see no anomalies.
Stretched cables? I have read somewhere a gentleman claimed cables cured his issue.
What now? Anything particular I need to look for?
After = Same
