[4th Gen : 01-07]: Catalytic converter
Old 07-30-2016, 06:50 PM
wheelchairman36's Avatar
wheelchairman36
wheelchairman36 is offline
Default Catalytic converter
The check engine light came back on yesterday and had autozone test it today and now it is the catalytic converter. How much does this effect the performance and especially the gas mileage. Performance/power is definitely up since tuneup but worried still about the gas mileage.
Old 07-30-2016, 06:56 PM
primem's Avatar
primem
primem is offline
if the dtc was p0420 catalyst efficiency and no other dtc; it will not effect driveability. This dtc usually sets when the catalyst is no longer doing what is should...oxidation reactions of C0 and hydrocarbons.
the only problems a cat will cause is if its clogged or has broken substrate moving around; this will cause a exhaust restriction.
Last edited by primem; 07-31-2016 at 09:39 PM. Reason: change reduction to oxidation
Old 07-30-2016, 10:00 PM
wheelchairman36
Error code-p0420 catalyst efficiency below normal (bank 1)
Old 07-31-2016, 09:19 AM
jkeaton is online now
Dodge Forum Administrator
It's either the sensor or the converter itself. All it does is monitor converter efficiency, as stated. No effect on engine performance.
Old 07-31-2016, 01:43 PM
Cougar41's Avatar
Cougar41
Cougar41 is offline
Just resetting the codes works many times.
Old 07-31-2016, 10:05 PM
wheelchairman36
TY. Hopefully it won't effect inspection in January.
Old 08-01-2016, 07:38 AM
If the check engine light is on, it will fail inspection. Start with replacing the sensor. If that does not work, time for a new converter.
Old 08-02-2016, 10:13 PM
wheelchairman36
Going to start with Lucas gas treatment with a full tank and run that a few days then reset the code and wait to see if it comes back on. If it does then on to the sensor. My mechanic explained to me that having a miss in cylinder three for sooo long could've messed up the converter.
Old 08-03-2016, 07:41 AM
He is correct. Sending unburned fuel from a misfire into the converter can ruin it in short time.
Old 08-04-2016, 12:19 AM
wheelchairman36
MPG done old fashion way and was 19.98mpg over 257 miles with about %60 highway use.
Quick Reply: [4th Gen : 01-07]: Catalytic converter
