[4th Gen : 01-07]: Turn signal always flashes LEFT
At first it was intermittent: sometimes the left lamps (including the dashboard indicator) would flash when the turn signal lever was pushed for a right turn. After a few tries, it would usually flash correctly for a right turn. Now it flashes the left lamps (including the dashboard indicator) every time the turn signals are activated, when the stick is pushed to either the left or right turn position.
Any ideas?
Any ideas?
http://ricksfreeautorepairadvice.com...gnal-problems/
Disconnect the negative battery cable to disable the airbag first.
