DodgeForum.com
DodgeForum.com Home - Dodge Marketplace - Dodge Photo Galleries - Create an Account - Dodge News
Go Back   DodgeForum.com > Dodge Vans > Dodge Caravan
Thread Tools Search this Thread
Old 06-26-2006, 10:34 AM
blaznblue blaznblue is offline
Default Help...99 Caravan Front Wheels Squeaking/Chirping Only While Driving
HELP
I have a 1999 Dodge Grand Caravan with a 3.3 engine. I recently purchase it and initially I replaced both front brake rotors and pads. As soon as I did that I noticed that the front cv joints were clicking. Car had 110k and I go on long trips and didn't trust past owner.
Anyway, while replacing both cv joints I replace ball joints and tie rods (both sides). I soon then had the car aligned and had no chirping/squeaking for about 40 miles. Then I heard the rear wheel bearing whining so I replace that.
As soon as I did that I could hear the drivers side wheel bearing whining so becasue I just got the vehicle and long trips I replace both fron wheel bearings. I had to take off the abs sensors and the calipers to change the hub bearing assembly.
Just as soon as I was done I heard the drivers side (louder than passenger) and passenger side wheel areas squeak and chirp; the sound get progressively louder with vehicle speed and starts at about 10 mph. Initially I tightened the hub nut on both sides, but nothing worked. So I looked for any TSB to no avail.
I tried one more thing...I jacked the vehicle up and then I untighted the hub nut and lug nuts (unload bearings and cv joint). I hand tightened the lugs and lowered vehicle. Then I tighted the hub nut to manufact. specs. I still had a squeaking/chirping sound.
Has anyone had a similar problem or encounted this problem?
Could I have damaged the cv axle? Wheel bearings?
(it doesn't seem like it though, this is my 6th dodge and third between 1996 and 2000 models minivan and I recently replaced my 1996 Plymouth Voyager's cv joint with no problem.)
Please help me...I am going crazy trying to figure this out and listening to this chirp.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on Dodge Forums!
Sponsored Links
Registered users do not see this ad.
Click here to register for free!
Old 06-27-2006, 03:06 AM
99Sport33L 99Sport33L is offline
Default RE: Help...99 Caravan Front Wheels Squeaking/Chirping Only While Driving
I have the 99 Grand Caravan Sport 3.3L and I heard squeaking when I was driving on the highway. The sound reflected off the side barrier. But I don't hear it when driving regular in the city. I hope this isn't a serious problem.
Old 06-27-2006, 11:16 AM
I don't think it is (all new parts), but it is annoying and I want to figure it out especially because notice at all speeds.
Old 06-27-2006, 01:13 PM
floorslayer1 floorslayer1 is offline
One time while replacing rotors on my 97GC a small chunk of rust got behind the rotor and it wasn't sitting flat on the hub. Besides a subtle vibration it also caused a chirp at almost all speeds. Cleaned and reset the rotor and it went away.
__________________
Caravan Fan....have owned 7 and praise their virtues, but woe their transnission flaws. I use a broken differential pin as a key chain if that's any sign. 2 1988 w/2.5l, 91 GC w/3.3, 94 GC AWD w/3.3, 2 1997's w/3.3 and 99 w/3.8
Old 07-03-2006, 09:35 PM
Turns out to be metal hub caps that I used from my older 1994 plymouth voyager. I did go back and clean mounting surface area for hub to rotor and rotor to wheel (helped a little). All gone now that I used some plastic hub caps... Thanks for your help.
Tags
1995, 2006, caravan, chirp, coming, dodge, driving, engine, grand, passanger, side, squeak, squeaks, squeal, squealing, van, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.2.0
