camshaft position sensor location in voyager 97
RE: camshaft position sensor location in voyager 97
ORIGINAL: robbieboy
hi there, i was told the camshaft position sensor is located inside the distributor, is this correct? i have some doubts about it
voyager 97 3.0 with distributor and code DTC P0340, service light on
thanks
thanks
ORIGINAL: brandoncrone
Ive never seen one go bad either, but anything is possible. It is inside the distributor, and the entire distributor has to be disassembled to replace it.
Could pull Dist. and make sure gear pin is fine and bushing feels tight.
Reset,clear and wait?
