2015 Dodge Charger LED Headlight Upgrade (HELP)
Old 02-15-2017, 05:09 AM
generalj14's Avatar
generalj14
generalj14 is offline
Question 2015 Dodge Charger LED Headlight Upgrade (HELP)
I bought some LED Headlights for my 2015 Charger. They are rated at 5200 Lumens per bulb. 10400 Lumens all together. They have a heat sink, fan...a true quality build. 9012 sockets, 55w ballast, 6000k color temp. They look amazing on the car, but I am having only one problem and I am hoping this great community can help. I installed the lights on the car and included warning cancellers as I heard they prevent errors and flickering. However the problem I have been having is my lights are on...seem to be running fine and then out of the blue they'll turn off and then about 2-3 seconds later they'll cut back on. They both do this at the exact same time. Sometimes it wont do it at all when im driving, but most of the time it does. I have noticed that when it does it 3 times the lights do not turn back on and I have to turn my car off and restart it for my lights to turn on again (I assume this to be some kind of 3 strike rule with the computer and restarting the car resets it). There is no issue with the bulb and ballast setup as they have been tested and are ok. Am I missing something? Do I need to add something to my setup to fix this? I LOVE how bright these lights are and they are the perfect color for the car. IMHO these are the kind of lights Dodge should have used instead of the ugly yellow halogen. It's tacky to have a nice, bright led halo and then an ugly yellow halogen bulb. Right now I have temporarily put halogens back because it poses a safety issue. Please help and thank you in advance
On a side note: I believe to have noticed a quick flicker...about a millisecond even with the halogen lights, but they don't turn off like my LED Headlight setup did. I was wondering if maybe that had something to do with it. I read around and heard of the computer pinging the headlights? Im new to Dodge so this info is all new to me. I hope someone can help me or point me in the right direction in solving this issue.
Old 02-21-2017, 01:10 AM
generalj14's Avatar
generalj14
I hope I posted this in the right area. If not please let me know and I'll move it. Hoping someone will see this soon and will be able to help
Old 02-22-2017, 07:53 AM
jkeaton is offline
Dodge Forum Administrator
You posted in the correct area. Unfortunately, this section is not that well attended. All I can say is newer vehicles do not play nice with aftermarket electronics. You might need an anti-flicker assembly and bypass the factory harness. These are wired straight to the battery. Like this:
Amazon Amazon
Old 03-06-2017, 01:51 PM
generalj14's Avatar
generalj14
Ah ok, I see. Thank you for your response. I did try using a relay harness with no luck. Maybe I didn't connect it correctly? Idk. I believe I connected it correctly, but instead of securing the part that connects to the positive battery terminal I set it up to where it was touching, but not bolted down. It had consistent contact, just wasn't secured down. However the lights ran, but had the same problem.
Old 03-14-2017, 06:54 PM
Timothycostin's Avatar
Timothycostin
Timothycostin is offline
I own a 2006 RT with 5.7 HEMI, only 78ooo miles.2 weeks ago the motor goes up.Loud clunking noise coming from engine. I think it is a broken crankshaft.I am having a Jasper installed $7000 later , throwing a p5 code in the dash ,any ideas?
Last edited by Timothycostin; 03-14-2017 at 06:59 PM. Reason: Throwing a P5 code ,any ideas
Old 04-09-2019, 09:57 PM
MWoody's Avatar
MWoody
MWoody is offline
Hey, I have a 2015 Dodge Charger as well and just bought a pair of XenonPro 9012 LEDs and I am experiencing the same exact issues. Did you ever find a solution to this problem?
Thanks!
