1959 D100 318 runs rich AGHHHH!
Old 10-18-2013, 11:50 AM
jfpizzaman's Avatar
jfpizzaman
jfpizzaman is offline
Default 1959 D100 318 runs rich AGHHHH!
So, I replaced the old Stromberg WW with a Mopar-remanufactured WW, and it still runs rich. Can't go any tighter on Mixture screws. Timing is good. What else could it be? Can the point setting affect this? PLEASE HELP! THANK YOU!
Old 10-31-2013, 08:40 PM
moe7404's Avatar
moe7404
moe7404 is offline
could be the fuel pump has to much pressure. or it is pumping trash into the carb. or bad float.
Old 11-02-2013, 12:45 PM
jfpizzaman's Avatar
jfpizzaman
Thanks again Moe. I'm waiting for new EI distributor and coil, then if it still runs rich I will get a fuel pump pressure regulator. Can't imagine what else it could be. I have to assume the carb is o.k. as it is a Mopar Reman. and I don't want to open it.
Old 11-07-2013, 08:18 AM
nibroc's Avatar
nibroc
nibroc is offline
the float level may be too high
Old 11-15-2013, 12:20 PM
jfpizzaman's Avatar
jfpizzaman
Thanks! Just installed HEI distributor (Chinese), and Pertronix Flamethrower coil, and it seems the rich smell is gone. Does anyone recommend opening the spark plug gap a bit as it suggests in Pertronix coil literature?
Old 11-15-2013, 03:49 PM
moe7404's Avatar
moe7404
moe7404 is offline
yes DO set the plug like Pertronix say. some CDI systems can be as high as .06-.08 inch. a long time ago i had delta mk 10. in a 1957 dodge PU i put some race plugs that was fuel fouled. they ran just fine.
Quick Reply: 1959 D100 318 runs rich AGHHHH!
