Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
v8 kit?
Old 11-07-2006, 10:48 AM
exline's Avatar
exline
exline is offline
Default RE: v8 kit?
d
  #42
Old 11-08-2006, 03:29 AM
Bcuzican's Avatar
Bcuzican
Bcuzican is offline
Default RE: v8 kit?
Sorry i dont have any pics , i dont think i ever took any. I am moving it to a diferent shop soon ill take some pics then. The leaf springs are from a AMC spirit. It was those or pinto springs [&:]
  #43
Old 11-10-2006, 12:14 PM
exline's Avatar
exline
exline is offline
Default RE: v8 kit?
V8 daytona burn out here is a video of the daytona doing a burnout.
  #44
Old 11-11-2006, 02:14 PM
bmc52387's Avatar
bmc52387
bmc52387 is offline
Default RE: v8 kit?
That's nice man. I wish I had the cash to do that to my Daytona.
  #45
Old 11-12-2006, 02:08 AM
Bcuzican's Avatar
Bcuzican
Bcuzican is offline
Default RE: v8 kit?
Nice clip!I built mine for burnout contests. I also have a 355 set up for mine running 245 50 16 on the rear . Im thinking of yanking out the springs and running a cal tracs set up in it its a bolt in deal .
  #46
Old 12-21-2006, 09:33 PM
braap546's Avatar
braap546
braap546 is offline
Default RE: v8 kit?
I just purchaced a rebuilt 318 and a used dakota rack to put in my 89 daytona and was wondering what are some of my options when it comes to the rear end and transmission. I really would like to have a manual trans and thats what the car is now. As for the rear end I have measured up some at a junkyard and found that a camaro rear axle would be close to fitting. I would just like some of your input on whats easiest to work with as well as be somewhat cheap. Thanks for any answers and I will be purchasing a k member from exline soon.
  #47
Old 12-22-2006, 10:16 AM
exline's Avatar
exline
exline is offline
Default RE: v8 kit?
as far as what rear will be easiest it really soesent make much difference unless you can find one the right width . i found the E body barracuda rears are the right width but i still had to redrill the axles for the right wheel bolt pattern. so the camaro might be the right size just make sure it is at least as you need it so if you have to narrow it you can.
i ran a 4 speed in mine so thats no problem . i am running a T56 6 speed now you can also get a hydraulic clutch kit from mcleod..you could really use about any transmission you want . I have used the A833 4 speed T56 six speed and the 727 automatic but i am sure you could fit anything else in there if you wanted.I f you are useing a 4 speed the e body transmission works best because the shifter is closer to where it needs to be.
  #48
Old 12-22-2006, 04:04 PM
89Daytona's Avatar
89Daytona
89Daytona is offline
Default RE: v8 kit?
There are places that offer new transmissions with the adapter to attach it to the engine. Your choice of transmissions really depends on the engine of choice and the availability of adapters for it and the trans.
http://www.keislerauto.com/mopar/tra...akota_5spd.asp
  #49
Old 08-10-2007, 06:36 PM
exline's Avatar
exline
exline is offline
Default RE: v8 kit?
havent been here in a while so i thought i would check in again.
  #50
Old 08-10-2007, 06:54 PM
damageincracing's Avatar
damageincracing
damageincracing is offline
Default RE: v8 kit?
Hey- long time no see. Welcome back, and all that. You may want to check your e-mail from your website... One of my instructors wants your input on a project of his. And we just got an 88 Daytona Shelby Z TurboII that I'm going to keep stock. Any idea where to get the blasted T-Top seals for one of these?!
