Dodge Intrepid The sporty car that recently left the Dodge lineup, the Dodge Intrepid. With it's smooth look and comfortable ride, the Dodge Intrepid can still command attention.
Broken tie rod bolt
Old 10-25-2014, 02:59 PM
THJ_307's Avatar
THJ_307
THJ_307 is offline
Default Broken tie rod bolt
Visit often but first time poster with a problem on my daughter's 2000 Intrepid.
While she was taking a corner the inner tie rod connection on drivers side broke free. I'm in the process of installing new tie rod bushings with a kit I've purchased but noticed that the old bolt appears to have been sheared off.
I'm assuming the broken piece is still in the steering gear because I can not get the replacement bolt to screw in, it will get a little tension like it's starting than go loose again....any suggestions?
Thanks.
Quick Reply: Broken tie rod bolt
