Electrical Issues ???
2009 Journey power door locks will not work using the key fob or buttons on the doors , making it impossible to open rear hatch and quite difficult to manually unlock the rear doors by jumping through the front seats. The key fob still arms and disarms the factory alarm system and remote starts the vehicle.
I have successfully tried resetting the computer by turning the key on and off 3 times which did nothing but give me an emissions error code. I tried removing the battery cables (no LUCK there) And I did find a blown fuse for the locks but when I tried to replace the fuse it just caused my front washer fluid to spray out until i removed the new fuse (weird huh). any help would be fantastic
You say your having problems with the FOB unlocking the doors in your first post, then you say your not having any issue with the FOB's. You replaced a blown fuse for the door locks but then removed it because it caused the windshield washer to spray. Sounds to me like there are malfunctions related to this recall.
I would suggest going ahead and having the recall work performed and go from there.
It looks like there is a TSB that could potentially relate to what you're experiencing. I recommend referencing the below TSB to your dealership.
TSB 23-004-09
SUBJECT:
Doors Do Not Lock Or Unlock Properly When Using Power Door Lock System Or Remote Keyless Entry
OVERVIEW:
This bulletin involves modifying the door trim panel to assure the lock **** will not interfere with it.
MODELS:
2009 (JC) Journey
NOTE: This Bulletin applies to vehicles built before August 6, 2008 (MDH 0806XX).
SYMPTOM/CONDITION:
Some customers may experience difficulty locking or unlocking the doors when using the power door lock system or remote keyless entry transmitter. Mechanical interference between the lock **** & door trim panel may be preventing the keyless entry system form operating properly.
TSB 23-004-09
SUBJECT:
OVERVIEW:
MODELS:
2009 (JC) Journey
SYMPTOM/CONDITION:
