transmission as a jack point?
So I got caught on the spot and had to jack up a 05 neon with a jack that was to tall to fit under the jack points. I raised it by what i think is the transmission case which is silver, rounded and in the middle of the car just forward of the front tires. I didnt raise both tires off the ground just one and just enough to change the flat. and didn't hear any thing that would indicate that something was damaged. It seemed like a sturdy spot but i just want to double check.
P.s. theres already an issue with the transmission as it doesn't shift smoothly at all. It also goes into high rpms while in park when it's cold out. (both were issues before the flat tire.
thanks
thanks
