Cp3 leak 07 5.9
Old 04-08-2011, 10:56 PM
built to last's Avatar
built to last
built to last is offline
Default Cp3 leak 07 5.9
Ok first of all its dark out and im kind of guessing on the location of the leak.
My CP3 has just started leaking on my 07 5.9 . It appears to be coming from the bottom or the side near the engine block. It is a low pressure high to med flow leak. There does not seem to be a loss of power or any air being sucked into the pump.
Any ideas? Anyone ever crack a pump body? It does not look like its coming from the gear body but again it dark in these here woods.
Old 04-09-2011, 02:54 PM
built to last
Default bump
bumped
Old 04-09-2011, 05:11 PM
built to last
First of all thanks to all of you that helped with this issue. Yes that's sarcasm.
But just so you all now the problem was a seal between the high and low pressure sides. The leak was from the blowout of the freeze plug near the bottom of the pump. I hope this info helps some one future diagnose there problem.
Old 04-13-2011, 03:11 PM
hottrodder67's Avatar
hottrodder67
hottrodder67 is offline
Default a LITTLE TO LATE
So i just saw this fourm if i saw it a couple days ago i would have told you its a seal. I had the exact same problem on my 06 5.9 I fixed it drove it for a month or two then ended up upgrading the pump for a bigger one. grabbed one from Industrial Injection. Now she purrs like a kitten on steroids hahaha.
Quick Reply: Cp3 leak 07 5.9
