Transmission oil?
Transmission oil?
Hello, I´m a new Dodge Van owner, and was thinking of to change the automatictransmission oil.
I wonderif I can use a DEXRON III (3)automatic transmission oil in my Dodge Ram Van -89 or is it a "too fine / good" oil for this transmission? I think I read some where that it should be a DEXRON II (2). Someone know?
And how much oil do I need?
The reason I wonder about the oil type is that I havesome unopendbottle of DEXRON III oil at home. Unnecessary to buy DEXRON II when I already have DEXRON III ifthe oil typedon´t matter.
Thanks,
Mattias
Thanks,
Mattias
RE: Transmission oil?
Dextron III supersedes Dextron II so you shouldn't have any problems using it as long as we're not talking about a minivan, in which case only use what's specified.
If you're dropping the pan and changing the filter as well, then the low/reverse band needs to be adjusted while you're in there. That is, if you want to save yourself a trannyrebuild job down the road.
