Dash Lights not working...
1994 B150 Window Van, V-6 short-base
Okay. I only have light on the speedo and the fuel gauges. I have changed the bulbs 2x, so, I know it is not that. I have switched the sockets around, so I know it's not THAT. So, i have to assume it's the board on the back of the cluster itself. Does this sound correct? If so, how do I go about getting a new or slightly used replacement? Can I just order that board from somewhere? Or do I need to order the whole cluster?
Suggestions? Insight?
Thanks in advance!
Thanks in advance!
Yeah, I did, even though I figured 1 fuse controlled all the lights, and with 2 of them working, it probably wouldn't be a fuse. But I checked em anyway. I think it's the board itself. I've been hearing that because they are like a printed circuit, the area around the lightbulbs tend to burn out. I was hoping someone would have some insight.
