1996 dodge van B2500 3.9L cavity #15/20yellow fuse keep blowing up
The RWAL lights is on, the fuse keep blowing up, according to the manual this fuse control RWAL. Do I need to change the Speed Sensor ? Does the speed sensor control the RWAL ? or could be a ground issue on the wire that feed the speed sensor ? This issue happened before but whet out by itself. I did check all the fuses, only cavity #15/ 20amp yellow is out. Any advise ?
Thank you and be safe
how I can get the ABS schematic?
