need 440 mounts for 85 b150 shorty
Old 02-28-2015, 07:04 AM
iodj44's Avatar
iodj44
iodj44 is offline
Man you have quite the van and there is plenty of time to sort out the small stuff before summer.
Old 03-01-2015, 11:15 PM
thevikingrules's Avatar
thevikingrules
thevikingrules is offline
Id put a rear sway bar on the 8 3/4 with adjustable coilovers have a new set of 295 / 50 /15 for rear on 10 inch rims want to run 10 up front to ,looking to try to put 245 50 15 on front it will give it a good wide look
Old 03-03-2015, 01:57 PM
iodj44's Avatar
iodj44
iodj44 is offline
I was wondering how did you manage the drive shaft, your original should not fit.
Old 03-13-2015, 10:30 AM
thevikingrules
the shaft wasnt hard had the original from the rr it was less then a foot longer then needed so had it shortened by a local shop for 150 . being a shorty there is no hanger bearing just a straight shaft
Old 03-13-2015, 12:37 PM
iodj44's Avatar
iodj44
iodj44 is offline
Yeah, I was just curious how you dealt with a couple things. The big block tranny I was fairly sure it was longer. Also you mentioned a high stall converter from the Road Runner did you decide to use it? I've got a 2600 converter in a 81 Mirada(360)with 484 intake lift and fairly long duration driving through a 904 and 3.55 posi, in hindsight think the stall is too high. Your stall speed is over 3000 rpm and behind a BB how is the noise and rpm at 65mph? One last question is did you convert to straight electronic ignition? I think your power and mileage will be better than whatever the van was running stock, may be mute question if the BB distributor is not compatible. I mean to say compatible with a stock 1985 emissions friendly ignition system which is set up to fire a lean running 318.
This will be one of those vehicles you will always remember owning, lots of war stories in you future.
Old 04-01-2015, 08:14 AM
blackvan's Avatar
blackvan
blackvan is offline
So, any photos of this swap? And how did you get your gauges working without a functional ECM ?
Old 04-09-2015, 12:40 AM
thevikingrules
that was easy about ecm it was a 318 2 bbl with a 904 tranny so no ecm in it to deal with , With the emissions the van didnt have lean burn on it so made life really easyall i did was run two after market cats before muffs and side pipes and is to old to have e test done on it any more . I changed everything over to electronic ignition all from doner car . didnt run the 3000 stall dropped to a 1800 to 2400 stall with a 391 gear ill get pics up here as soon as i down load them off phone
Old 05-02-2015, 05:48 PM
blackvan's Avatar
blackvan
blackvan is offline
Sounds like fun Hope you upload a few pics for us at some point, love to see this.
Old 06-06-2015, 09:14 PM
thevikingrules
have a few pics more to come later this is doner camper for all mounts that were needed and new 440 for my 85
Old 06-07-2015, 11:10 AM
iodj44's Avatar
iodj44
iodj44 is offline
Very nice. How does she run?
Quick Reply: need 440 mounts for 85 b150 shorty
