Mine had begun howling in 2010, then the howling turned into loud grinding and no forward motion when the rear end went out. I don't clearly recall but believe it was the axle and bearing on driver side was toast and the other side soon to follow. better get it looked at, it ain't cheap.
I should have mentioned that mine whines only when under load but when let off accelerater whine stops. Is this common for a u-joint or differential problem such as worn ring and pinion or bearings?
