wet carpet in cab
Old 10-19-2016, 01:36 PM
anlake2's Avatar
anlake2
anlake2 is offline
Question wet carpet in cab
!999 DRV 1500 losing water? no signs took mats out today! Carpet is very wet.. running from behind driver seat to the rear! I need help
Old 10-19-2016, 01:43 PM
jkeaton is offline
Dodge Forum Administrator
Heater core, weather stripping (you don't say if it happens only in the rain or what), AC drain tube....is it just water?
Old 10-19-2016, 01:58 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Dodge Forum Moderator
It can be so many things. Do you have rear heat? Try and answer the questions jkeaton posted above.
Old 10-19-2016, 02:36 PM
anlake2's Avatar
anlake2
anlake2 is offline
I have rear ht and air fan, I have been using water, could not find where. no water on the front floor. Have been using my air a lot idling while waiting to pick up grandkids. When I pulled up my car mats to clean, from the driver seat to the rear was very wet. Checked my water {low) Just didn't think of looking on the left side, as I checked to see if it was the heater core I looked on the right.
Old 10-19-2016, 03:48 PM
anlake2's Avatar
anlake2
anlake2 is offline
Thinking it might be the ac drain tube. How do I locate this? Seems it happens after I have run the air a lot. Hot here! It is all on the left from the back of the driver seat to the very rear Carpet is somewhat sticky.. probably leaking longer then I realized
Old 10-20-2016, 12:50 AM
alloro's Avatar
alloro
alloro is offline
If the condensate drain is plugged then the water will back up into the heating vents and eventually spill out onto the floor. The drain is under the van behind the front right tire.
