03 3500 ext Shudder / noise in reverse when turning sharply.
2003 3500 Ram van Ext RWD.
I've been going thru it a piece at a time and getting it in pretty good shape. Runs, drives beautifully. No (longer) any OBD codes. May just need tires.
I've noticed that when in reverse and turning sharply at low speeds (like backing into a parking space, or doing a sharp 3-pointer) I hear and feel a "shudder". It "sounds like" the front tires are rubbing, but I am concerned it could be a differential or trans issue. U-joints maybe? No problems in any of the forward gears. Whether turning sharply or not.
Bringing it in to my local guy on Monday to see what he thinks.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
Yes, in reverse while turning you are stressing the wheels in the opposite direction than if turning while moving forward. (pull versus push) A combination of worn bushings and alignment adjustments that might already favor one extreme over the other can cause the condition while moving in one direction and not the other.
