2007 to 2008 3.5 gas engine codes
on
MODULE, Powertrain Control (PCM)
Diagnosis and Testing
0059-CAMSHAFT POSITION ACTUATOR 1/2 TARGET PERFORMANCE
0060-CAMSHAFT POSITION ACTUATOR 1/2 TARGET PERFORMANCE
0063-CAMSHAFT POSITION ACTUATOR 2/2 TARGET PERFORMANCE
0064-CAMSHAFT POSITION ACTUATOR 2/2 TARGET PERFORMANCE
0065-CAMSHAFT POSITION ACTUATOR 1/2 CONTROL CIRCUIT HIGH
0066-CAMSHAFT POSITION ACTUATOR 1/2 CONTROL CIRCUIT LOW
0067-CAMSHAFT POSITION ACTUATOR 1/2 CONTROL CIRCUIT/OPEN
0069-CAMSHAFT POSITION ACTUATOR 2/2 CONTROL CIRCUIT HIGH
0070-CAMSHAFT POSITION ACTUATOR 2/2 CONTROL CIRCUIT LOW
0071-CAMSHAFT POSITION ACTUATOR 2/2 CONTROL CIRCUIT/OPEN
0073-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH
0077-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW
0081-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH
0085-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW
0089-THROTTLE POSITION SENSOR 1/2 CORRELATION HGH
0093-ACCELERATOR PEDAL POSITION SENSOR 5 VOLT SUPPLY CIRCUIT
0113-IMPLAUSIBLE STOP LAMP SWITCH SIGNAL RECEIVED
0117-CRANKSHAFT POSITION SENSOR CIRCUIT/OPEN
0119-CRANKSHAFT POSITION SENSOR CIRCUIT/OPEN
0120-CRANKSHAFT POSITION SENSOR CIRCUIT/OPEN
0153-THERMOSTAT CONTROL CIRCUIT HIGH
0154-THERMOSTAT CONTROL CIRCUIT LOW
0155-THERMOSTAT CONTROL CIRCUIT/OPEN
0160-ACTUAL VALUE POTENTIOMETER FOR THROTTLE VALVE IS FAULTY
0161-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH
0162-THROTTLE POSITION SENSOR 1 CIRCUIT LOW
0164-THROTTLE POSITION SENSOR 1 CIRCUIT/OPEN
0165-THROTTLE POSITION SENSOR 2 CIRCUIT HIGH
0166-THROTTLE POSITION SENSOR 2 CIRCUIT LOW
0168-THROTTLE POSITION SENSOR 2 CIRCUIT/OPEN
0185-ELECTRONIC THROTTLE CONTROL SYSTEM - OUTPUT STAGE
0186-ELECTRONIC THROTTLE CONTROL SYSTEM - OUTPUT STAGE
0187-ELECTRONIC THROTTLE CONTROL SYSTEM - OUTPUT STAGE
0188-ELECTRONIC THROTTLE CONTROL SYSTEM - OUTPUT STAGE
0189-ELECTRONIC THROTTLE CONTROL SYSTEM - MECHANICAL FAULT
0190-ELECTRONIC THROTTLE CONTROL SYSTEM - MECHANICAL FAULT
0193-ELECTRONIC THROTTLE CONTROL SYSTEM - MECHANICAL FAULT
0194-ELECTRONIC THROTTLE CONTROL SYSTEM - MECHANICAL FAULT
0200-ELECTRONIC THROTTLE CONTROL SYSTEM - POSITION
0204-ELECTRONIC THROTTLE CONTROL SYSTEM - SAFETY FUEL SHUTOFF DETECTED
0205-ELECTRONIC THROTTLE CONTROL SYSTEM - POSITION
0206-ELECTRONIC THROTTLE CONTROL SYSTEM - POSITION
0212-ELECTRONIC THROTTLE CONTROL SYSTEM - MOTOR WAS REPLACED
0216-ELECTRONIC THROTTLE CONTROL SYSTEM - THROTTLE VALVE ADAPTATION IS FAULTY
0217-ELECTRONIC THROTTLE CONTROL SYSTEM - ENVIRONMENTAL CONDITIONS
0218-ELECTRONIC THROTTLE CONTROL SYSTEM - LOW VOLTAGE
0224-ELECTRONIC THROTTLE CONTROL SYSTEM - PERFORM THROTTLE VALVE ADAPTATION
0228-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE
0230-O2 SENSOR 1/1 SIGNAL LOW
0234-O2 SENSOR 2/1 SIGNAL LOW
0271-CAMSHAFT POSITION ACTUATOR 1/1 TARGET PERFORMANCE
0272-CAMSHAFT POSITION ACTUATOR 1/1 TARGET PERFORMANCE
0275-CAMSHAFT POSITION ACTUATOR 2/1 TARGET PERFORMANCE
0276-CAMSHAFT POSITION ACTUATOR 2/1 TARGET PERFORMANCE
0277-CAMSHAFT POSITION ACTUATOR 1/1 CONTROL CIRCUIT HIGH
0278-CAMSHAFT POSITION ACTUATOR 1/1 CONTROL CIRCUIT LOW
0279-CAMSHAFT POSITION ACTUATOR 1/1 CONTROL CIRCUIT/OPEN
0281-CAMSHAFT POSITION ACTUATOR 2/1 CONTROL CIRCUIT HIGH
0282-CAMSHAFT POSITION ACTUATOR 2/1 CONTROL CIRCUIT LOW
0283-CAMSHAFT POSITION ACTUATOR 2/1 CONTROL CIRCUIT/OPEN
0301-FUEL INJECTOR 1 CIRCUIT HIGH
0302-FUEL INJECTOR 1 CIRCUIT LOW
0303-FUEL INJECTOR 1 CIRCUIT/OPEN
0305-FUEL INJECTOR 4 CIRCUIT HIGH
0306-FUEL INJECTOR 4 CIRCUIT LOW
0307-FUEL INJECTOR 4 CIRCUIT/OPEN
0309-FUEL INJECTOR 3 CIRCUIT HIGH
0310-FUEL INJECTOR 3 CIRCUIT LOW
0311-FUEL INJECTOR 3 CIRCUIT/OPEN
0313-FUEL INJECTOR 6 CIRCUIT HIGH
0314-FUEL INJECTOR 6 CIRCUIT LOW
0315-FUEL INJECTOR 6 CIRCUIT/OPEN
0317-FUEL INJECTOR 2 CIRCUIT HIGH
0318-FUEL INJECTOR 2 CIRCUIT LOW
0319-FUEL INJECTOR 2 CIRCUIT/OPEN
0321-FUEL INJECTOR 5 CIRCUIT HIGH
0322-FUEL INJECTOR 5 CIRCUIT LOW
0323-FUEL INJECTOR 5 CIRCUIT/OPEN
0365-GENERATOR SYSTEM PERFORMANCE
0386-ENGINE CAN BUS - THE CODING FOR COMPONENT TRANSMISSION CONTROL UNIT
0386-IMPLAUSIBLE TRANSMISSION DATA RECEIVED
0387-ENGINE CAN BUS - THE CODING FOR COMPONENT TRANSMISSION CONTROL UNIT
0387-IMPLAUSIBLE TRANSMISSION DATA RECEIVED
0390-ENGINE CAN BUS - THE CODING FOR COMPONENT TRANSMISSION CONTROL UNIT
0390-IMPLAUSIBLE TRANSMISSION DATA RECEIVED
0391-ENGINE CAN BUS - THE CODING FOR COMPONENT TRANSMISSION CONTROL UNIT
0391-IMPLAUSIBLE TRANSMISSION DATA RECEIVED
0420-O2 SENSOR 1/2 HEATER PERFORMANCE
0424-O2 SENSOR 1/2 HEATER PERFORMANCE
0425-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
0426-O2 SENSOR 1/2 HEATER CIRCUIT LOW
0427-O2 SENSOR 1/2 HEATER CIRCUIT
0429-O2 SENSOR 1/2 HEATER PERFORMANCE
0430-O2 SENSOR 1/2 HEATER PERFORMANCE
0431-O2 SENSOR 1/2 HEATER PERFORMANCE
0433-O2 SENSOR 1/1 HEATER CIRCUIT
0435-ECM INTERNAL FAULT
0436-O2 SENSOR 1/1 HEATER CIRCUIT
0437-O2 SENSOR 2/1 HEATER CIRCUIT HIGH
0438-O2 SENSOR 2/1 HEATER CIRCUIT LOW
0439-ECM INTERNAL FAULT
0440-O2 SENSOR 2/1 HEATER PERFORMANCE
0441-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
0442-O2 SENSOR 1/1 HEATER CIRCUIT LOW
0443-O2 SENSOR 1/1 HEATER CIRCUIT
0445-O2 SENSOR 2/1 HEATER PERFORMANCE
0446-O2 SENSOR 2/1 HEATER PERFORMANCE
0447-O2 SENSOR 2/1 HEATER PERFORMANCE
0449-PCM INTERNAL FAULT
0450-ECM INTERNAL FAULT
0451-ECM INTERNAL FAULT
0452-ECM INTERNAL FAULT
0453-ECM INTERNAL FAULT
0454-ECM INTERNAL FAULT
0455-ECM INTERNAL FAULT
0456-ECM INTERNAL FAULT
0485-COOLANT TEMPERATURE TOO HIGH
0489-FUEL PUMP CONTROL CIRCUIT HIGH
0490-FUEL PUMP CONTROL CIRCUIT LOW
0491-FUEL PUMP CONTROL CIRCUIT/OPEN
0493-KNOCK SENSOR SYSTEM ERROR
0494-KNOCK SENSOR SYSTEM ERROR
0496-KNOCK SENSOR SYSTEM ERROR
0500-KNOCK SENSOR SYSTEM ERROR
0501-KNOCK SENSOR 1 CIRCUIT
0502-KNOCK SENSOR 1 CIRCUIT
0504-KNOCK SENSOR 1 CIRCUIT
0505-KNOCK SENSOR 2 CIRCUIT
0506-KNOCK SENSOR 2 CIRCUIT
0508-KNOCK SENSOR 2 CIRCUIT
0509-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
0510-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH
0511-O2 SENSOR 1/2 SLOW RESPONSE
0513-O2 SENSOR 2/2 SLOW RESPONSE
0514-O2 SENSOR 2/2 SLOW RESPONSE
0515-O2 SENSOR 2/2 SLOW RESPONSE
0521-INTAKE MANIFOLD FLOW VALVE CONTROL CIRCUIT
0522-INTAKE MANIFOLD FLOW VALVE CONTROL CIRCUIT
0524-INTAKE MANIFOLD FLOW VALVE CONTROL CIRCUIT
0537-MASS AIR FLOW SENSOR CIRCUIT
0549-O2 SENSOR 1/2 CIRCUIT
0550-O2 SENSOR 1/2 CIRCUIT LOW
0551-O2 SENSOR 1/2 CIRCUIT LOW
0552-O2 SENSOR 1/2 CIRCUIT
0553-O2 SENSOR 2/2 CIRCUIT HIGH
0554-O2 SENSOR 2/2 CIRCUIT LOW
0555-O2 SENSOR 2/2 HEATER CIRCUIT
0556-O2 SENSOR 2/2 CIRCUIT
0559-O2 SENSOR 1/2 CIRCUIT
0563-O2 SENSOR 2/1 CIRCUIT
0565-O2 SENSOR 1/1 CIRCUIT
0567-O2 SENSOR 1/1 CIRCUIT
0568-O2 SENSOR 1/1 CIRCUIT
0569-O2 SENSOR 1/1 CIRCUIT
0571-O2 SENSOR 1/1 CIRCUIT
0572-O2 SENSOR 1/1 CIRCUIT
0573-O2 SENSOR 1/1 CIRCUIT
0574-O2 SENSOR 1/1 CIRCUIT
0577-O2 SENSOR 1/1 CIRCUIT
0578-O2 SENSOR 1/1 CIRCUIT
0583-O2 SENSOR 1/1 CIRCUIT
0587-O2 SENSOR 1/1 CIRCUIT
0591-O2 SENSOR 1/1 CIRCUIT
0595-O2 SENSOR 2/1 CIRCUIT
0600-O2 SENSOR UPSTREAM CONNECTORS MAY BE REVERSED
0620-HIGH AIRFLOW/VACUUM LEAK DETECTED
0629-SINGLE CYLINDER MISFIRE
0630-SINGLE CYLINDER MISFIRE
0632-SINGLE CYLINDER MISFIRE
0633-CYLINDER 1 MISFIRE
0634-CYLINDER 1 MISFIRE
0636-CYLINDER 1 MISFIRE
0637-CYLINDER 4 MISFIRE
0638-CYLINDER 4 MISFIRE
0640-CYLINDER 4 MISFIRE
0641-CYLINDER 3 MISFIRE
0642-CYLINDER 3 MISFIRE
0644-CYLINDER 3 MISFIRE
0645-CYLINDER 6 MISFIRE
0646-CYLINDER 6 MISFIRE
0648-CYLINDER 6 MISFIRE
0649-CYLINDER 2 MISFIRE
0650-CYLINDER 2 MISFIRE
0652-CYLINDER 2 MISFIRE
0653-CYLINDER 5 MISFIRE
0654-CYLINDER 5 MISFIRE
0656-CYLINDER 5 MISFIRE
0703-CRANKSHAFT POSITION SENSOR CIRCUIT/OPEN
0704-CRANKSHAFT POSITION SENSOR CIRCUIT/OPEN
0732-CAMSHAFT POSITION ACTUATOR 1/2 TARGET PERFORMANCE
0736-CAMSHAFT POSITION ACTUATOR 2/2 TARGET PERFORMANCE
0740-CAMSHAFT POSITION ACTUATOR 1/1 TARGET PERFORMANCE
0744-CAMSHAFT POSITION ACTUATOR 2/1 TARGET PERFORMANCE
0753-CAMSHAFT POSITION SENSOR 1/1 CIRCUIT HIGH
0754-CAMSHAFT POSITION SENSOR 1/1 CIRCUIT LOW
0755-CAMSHAFT POSITION SENSOR 1/1 PERFORMANCE
0756-CAMSHAFT POSITION SENSOR 1/1 PERFORMANCE
0757-CAMSHAFT POSITION SENSOR 2/1 CIRCUIT HIGH
0758-CAMSHAFT POSITION SENSOR 2/1 CIRCUIT LOW
0759-CAMSHAFT POSITION SENSOR 2/1 PERFORMANCE
0760-CAMSHAFT POSITION SENSOR 2/1 PERFORMANCE
0761-CAMSHAFT POSITION SENSOR 1/2 CIRCUIT HIGH
0762-CAMSHAFT POSITION SENSOR 1/2 CIRCUIT LOW
0763-CAMSHAFT POSITION SENSOR 1/2 PERFORMANCE
0764-CAMSHAFT POSITION SENSOR 1/2 PERFORMANCE
0765-CAMSHAFT POSITION SENSOR 2/2 CIRCUIT HIGH
0766-CAMSHAFT POSITION SENSOR 2/2 CIRCUIT LOW
0767-CAMSHAFT POSITION SENSOR 2/2 PERFORMANCE
0768-CAMSHAFT POSITION SENSOR 2/2 PERFORMANCE
0771-CAMSHAFT POSITION SENSOR 1/1 PERFORMANCE
0773-O2 SENSOR 1/1 SLOW RESPONSE
0775-O2 SENSOR 1/1 SLOW RESPONSE
0776-O2 SENSOR 1/1 SLOW RESPONSE
0777-O2 SENSOR 2/1 SLOW RESPONSE
0778-O2 SENSOR 2/1 SLOW RESPONSE
0779-O2 SENSOR 2/1 SLOW RESPONSE
0780-O2 SENSOR 2/1 SLOW RESPONSE
0810-SECONDARY AIR INJECTION SYSTEM - BANK 1
0817-SECONDARY AIR INJECTION SYSTEM SWITCHING VALVE CIRCUIT/OPEN
0821-SECONDARY AIR INJECTION SYSTEM SWITCHING VALVE CIRCUIT/OPEN
0845-ENGINE CAN BUS - THE TORQUE REQUEST FROM TRANSMISSION CONTROL MODULE IS IMPLAUSIBLE
0845-IMPLAUSIBLE TORQUE REQUEST DATA RECEIVED
0849-EVAP PURGE CONTROL CIRCUIT HIGH
0850-EVAP PURGE CONTROL CIRCUIT LOW
0851-EVAP PURGE CONTROL CIRCUIT/OPEN
0856-THERMOSTAT CONTROL PERFORMANCE
0857-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH
0858-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW
0859-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW
0860-ENGINE COOLANT TEMPERATURE SENSOR PERFORMANCE
0865-BATTERY VOLTAGE HIGH
0866-BATTERY VOLTAGE LOW
0872-FAULT OF FUNCTION MONITOR IN ELECTRONIC ACCELERATOR
0876-ECM INTERNAL FAULT
0889-ECM INTERNAL FAULT
0890-ECM INTERNAL FAULT
0891-ECM INTERNAL FAULT
0893-ECM INTERNAL FAULT
0984-ECM INTERNAL FAULT
0895-ECM INTERNAL FAULT
0897-ECM INTERNAL FAULT
0898-ECM INTERNAL FAULT
0900-ECM INTERNAL FAULT
0904-ECM INTERNAL FAULT
0908-ECM INTERNAL FAULT
0908-O2 SENSOR 1/1 CIRCUIT PERFORMANCE
0912-O2 SENSOR 2/1 CIRCUIT PERFORMANCE
0916-ECM INTERNAL FAULT
0920-ECM INTERNAL FAULT
0922-ECM INTERNAL FAULT
0923-ECM INTERNAL FAULT
0924-ECM INTERNAL FAULT
0927-UNKNOWN FAULT CODE UNKNOWN FAULT TYPE: 0
0940-IMPLAUSIBLE STOP LAMP SWITCH SIGNAL RECEIVED
0942-CATALYST EFFICIENCY BANK 1
0946-CATALYST EFFICIENCY BANK 2
0954-EVAP PURGE SYSTEM PERFORMANCE
0957-EVAP PURGE CONTROL CIRCUIT HIGH
0958-EVAP PURGE CONTROL CIRCUIT LOW
0959-EVAP PURGE CONTROL CIRCUIT/OPEN
0961- EVAP SYSTEM - LOOSE FUEL CAP
0976-ECM INTERNAL FAULT
0981-IGNITION COIL 1 PRIMARY CIRCUIT HIGH
0982-IGNITION COIL 1 PRIMARY CIRCUIT LOW
0983-IGNITION COIL 1 PRIMARY CIRCUIT/OPEN
0984-IGNITION COIL 1 PRIMARY CIRCUIT PERFORMANCE
0985-IGNITION COIL 4 PRIMARY CIRCUIT HIGH
0986-IGNITION COIL 4 PRIMARY CIRCUIT LOW
0987-IGNITION COIL 4 PRIMARY CIRCUIT/OPEN
0988-IGNITION COIL 4 PRIMARY CIRCUIT PERFORMANCE
0989-IGNITION COIL 3 PRIMARY CIRCUIT HIGH
0990-IGNITION COIL 3 PRIMARY CIRCUIT LOW
0991-IGNITION COIL 3 PRIMARY CIRCUIT/OPEN
0992-IGNITION COIL 3 PRIMARY CIRCUIT PERFORMANCE
0993-IGNITION COIL 6 PRIMARY CIRCUIT HIGH
0994-IGNITION COIL 6 PRIMARY CIRCUIT LOW
0995-IGNITION COIL 6 PRIMARY CIRCUIT/OPEN
0996-IGNITION COIL 6 PRIMARY CIRCUIT PERFORMANCE
0997-IGNITION COIL 2 PRIMARY CIRCUIT HIGH
0998-IGNITION COIL 2 PRIMARY CIRCUIT LOW
0999-IGNITION COIL 2 PRIMARY CIRCUIT/OPEN
1000-IGNITION COIL 2 PRIMARY CIRCUIT PERFORMANCE
1001-IGNITION COIL 5 PRIMARY CIRCUIT HIGH
1002-IGNITION COIL 5 PRIMARY CIRCUIT LOW
1003-IGNITION COIL 5 PRIMARY CIRCUIT/OPEN
1004-IGNITION COIL 5 PRIMARY CIRCUIT PERFORMANCE
1013-IGNITION COIL 1 OUTPUT STAGE CIRCUIT HIGH
1014-IGNITION COIL 1 OUTPUT STAGE CIRCUIT LOW
1015-IGNITION COIL 1 OUTPUT STAGE CIRCUIT PERFORMANCE
1016-IGNITION COIL 1 OUTPUT STAGE CIRCUIT/OPEN
1017-IGNITION COIL 4 OUTPUT STAGE CIRCUIT HIGH
1018-IGNITION COIL 4 OUTPUT STAGE CIRCUIT LOW
1019-IGNITION COIL 4 OUTPUT STAGE CIRCUIT PERFORMANCE
1023-IGNITION COIL 3 OUTPUT STAGE CIRCUIT PERFORMANCE
1024-IGNITION COIL 3 OUTPUT STAGE CIRCUIT/OPEN
1025-IGNITION COIL 6 OUTPUT STAGE CIRCUIT HIGH
1026-IGNITION COIL 6 OUTPUT STAGE CIRCUIT LOW
1027-IGNITION COIL 6 OUTPUT STAGE CIRCUIT PERFORMANCE
1028-IGNITION COIL 6 OUTPUT STAGE CIRCUIT/OPEN
1029-IGNITION COIL 2 OUTPUT STAGE CIRCUIT HIGH
1030-IGNITION COIL 2 OUTPUT STAGE CIRCUIT LOW
1031-IGNITION COIL 2 OUTPUT STAGE CIRCUIT PERFORMANCE
1032-IGNITION COIL 2 OUTPUT STAGE CIRCUIT/OPEN
1033-IGNITION COIL 5 OUTPUT STAGE CIRCUIT HIGH
1034-IGNITION COIL 5 OUTPUT STAGE CIRCUIT LOW
1035-IGNITION COIL 5 OUTPUT STAGE CIRCUIT PERFORMANCE
1036-IGNITION COIL 5 OUTPUT STAGE CIRCUIT/OPEN
1045-O2 SENSOR 1/1 STUCK RICH
1046-O2 SENSOR 1/1 STUCK LEAN
1047-O2 SENSOR 1/1 SIGNAL INACTIVE
1048-O2 SENSOR 1/1 SIGNAL PERFORMANCE
1049-O2 SENSOR 2/1 STUCK RICH
1050-O2 SENSOR 2/1 STUCK LEAN
1051-O2 SENSOR 2/1 SIGNAL INACTIVE
1052-O2 SENSOR 2/1 SIGNAL PERFORMANCE
1053-O2 SENSOR 1/1 CIRCUIT HIGH
1057-O2 SENSOR 2/2 CIRCUIT HIGH
1065-SECONDARY AIR INJECTION PUMP RELAY CIRCUIT HIGH
1066-SECONDARY AIR INJECTION PUMP RELAY CIRCUIT LOW
1067-SECONDARY AIR INJECTION PUMP RELAY CIRCUIT/OPEN
1069-SECONDARY AIR INJECTION SYSTEM SWITCHING VALVE CIRCUIT/OPEN
1070-SECONDARY AIR INJECTION SYSTEM SWITCHING VALVE CIRCUIT/OPEN
1071-SECONDARY AIR INJECTION SYSTEM SWITCHING VALVE CIRCUIT/OPEN
1073-MANIFOLD FLOW VALVE CONTROL CIRCUIT HIGH
1074-MANIFOLD FLOW VALVE CONTROL CIRCUIT LOW
1075-MANIFOLD FLOW VALVE CONTROL CIRCUIT/OPEN
1077-EVAP PURGE SYSTEM PERFORMANCE
1078-EVAP PURGE SYSTEM PERFORMANCE
1081-EVAP SYSTEM - MEDIUM LEAK
1085-EVAP PURGE SYSTEM - LARGE LEAK
1089-EVAP PURGE SYSTEM - SMALL LEAK
1097-EVAP PURGE SYSTEM PERFORMANCE
1101-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH
1102-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW
1103-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT PERFORMANCE
1104-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT PERFORMANCE
1105-MAIN RELAY CONTROL CIRCUIT HIGH
1106-MAIN RELAY CONTROL CIRCUIT LOW
1108-MAIN RELAY CONTROL CIRCUIT/OPEN
1117-ECM INTERNAL FAULT
1118-ECM INTERNAL FAULT
1119-ECM INTERNAL FAULT
1185-INTAKE MANIFOLD RUNNER (SWIRL) CONTROL CIRCUIT HIGH
1186-INTAKE MANIFOLD RUNNER (SWIRL) CONTROL CIRCUIT LOW
1187-INTAKE MANIFOLD RUNNER (SWIRL) CONTROL CIRCUIT/OPEN
1197-CRANKSHAFT/CAMSHAFT 1/2 TIMING MISALIGNMENT
1198-CRANKSHAFT/CAMSHAFT 1/2 TIMING MISALIGNMENT
1199-CRANKSHAFT/CAMSHAFT 1/2 TIMING MISALIGNMENT
1200-CRANKSHAFT/CAMSHAFT 1/2 TIMING MISALIGNMENT
1201-CRANKSHAFT/CAMSHAFT 2/2 TIMING MISALIGNMENT
1202-CRANKSHAFT/CAMSHAFT 2/2 TIMING MISALIGNMENT
1203-CRANKSHAFT/CAMSHAFT 2/2 TIMING MISALIGNMENT
1204-CRANKSHAFT/CAMSHAFT 2/2 TIMING MISALIGNMENT
1205-CRANKSHAFT/CAMSHAFT 1/1 TIMING MISALIGNMENT
1206-CRANKSHAFT/CAMSHAFT 1/1 TIMING MISALIGNMENT
1207-CRANKSHAFT/CAMSHAFT 1/1 TIMING MISALIGNMENT
1208-CRANKSHAFT/CAMSHAFT 1/1 TIMING MISALIGNMENT
1209-CRANKSHAFT/CAMSHAFT 2/1 TIMING MISALIGNMENT
1210-CRANKSHAFT/CAMSHAFT 2/1 TIMING MISALIGNMENT
1211-CRANKSHAFT/CAMSHAFT 2/1 TIMING MISALIGNMENT
1212-CRANKSHAFT/CAMSHAFT 2/1 TIMING MISALIGNMENT
1305-POWER STEERING CONTROL CIRCUIT HIGH
1306-POWER STEERING CONTROL CIRCUIT LOW
1307-POWER STEERING CONTROL CIRCUIT
1313-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE / SHORT CIRCUIT TO MOTOR (+)
1314-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE / SHORT CIRCUIT TO GROUND
1315-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE / OPEN CIRCUIT
1316-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE / SIGNAL IMPLAUSIBLE
1345-MASS AIR FLOW SENSOR LOOSE CONTACT WITH LOW FREQUENCY
1346-MASS AIR FLOW SENSOR LOOSE CONTACT WITH HIGH FREQUENCY
1347-MASS AIR FLOW SENSOR CIRCUIT LOW
1349-MASS AIR FLOW / THROTTLE POSITION CORRELATION
1350-MASS AIR FLOW SENSOR SIGNAL BELOW RANGE
1351-MASS AIR FLOW SENSOR CIRCUIT PERFORMANCE
1352-MASS AIR FLOW SENSOR CIRCUIT PERFORMANCE
1360-O2 SENSOR DOWNSTREAM CONNECTORS MAY BE REVERSED
1389-SECONDARY AIR INJECTION SYSTEM
1390-SECONDARY AIR INJECTION SYSTEM
1392-SECONDARY AIR INJECTION SYSTEM
1461-IMPLAUSIBLE ENGINE COOLANT TEMPERATURE MESSAGE
1462-IMPLAUSIBLE ENGINE COOLANT TEMPERATURE MESSAGE
1463-IMPLAUSIBLE ENGINE COOLANT TEMPERATURE MESSAGE
1464-IMPLAUSIBLE ENGINE COOLANT TEMPERATURE MESSAGE
1599-AMBIENT AIR TEMPERATURE PERFORMANCE-LOW
1600-AMBIENT AIR TEMPERATURE PERFORMANCE-HIGH
1757-FAULT PRESENT IN EGS CONTROL MODULE
1901-ENGINE OIL PRESSURE SENSOR PERFORMANCE
1902-ENGINE OIL PRESSURE SENSOR PERFORMANCE
1909-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH
1910-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT LOW
1913-MANIFOLD ABSOLUTE PRESSURE SENSOR PERFORMANCE
1914-MANIFOLD ABSOLUTE PRESSURE SENSOR PERFORMANCE
1915-MANIFOLD ABSOLUTE PRESSURE SENSOR PERFORMANCE
1916-MANIFOLD ABSOLUTE PRESSURE SENSOR PERFORMANCE
2025-INTAKE AIR TEMPERATURE SENSOR CIRCUIT LOW
2026-INTAKE AIR TEMPERATURE SENSOR CIRCUIT HIGH
2029-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
2030-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
2032-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
2045-FUEL LEVEL SENSOR 1 PERFORMANCE
2046-FUEL LEVEL SENSOR 1 PERFORMANCE
2048-FUEL LEVEL SENSOR 1 PERFORMANCE
2065-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT LOW
2066-ENGINE COOLANT TEMPERATURE SENSOR CIRCUIT HIGH
2067-MASS AIR FLOW SENSOR SHORT/OPEN CIRCUIT
2068-MASS AIR FLOW SENSOR SHORT/OPEN CIRCUIT
2069-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT LOW
2070-AMBIENT AIR TEMPERATURE SENSOR CIRCUIT HIGH
2089-FUEL SYSTEM RICH - BANK 1
2090-FUEL SYSTEM LEAN - BANK 1
2091-FUEL SYSTEM RICH - BANK 1
2092-FUEL SYSTEM LEAN - BANK 1
2093-FUEL SYSTEM RICH - BANK 2
2094-FUEL SYSTEM LEAN - BANK 2
2095-FUEL SYSTEM RICH - BANK 2
2096-FUEL SYSTEM LEAN - BANK 2
2145-FUEL PUMP CONTROL CIRCUIT LOW
2177-POWER STEERING CONTROL CIRCUIT HIGH
2181-MASS AIR FLOW SENSOR UPPER SWITCHING THRESHOLD ABOVE SPECIFICATION
2182-MASS AIR FLOW SENSOR LOWER SWITCHING THRESHOLD ABOVE SPECIFICATION
2185-IDLE SPEED PERFORMANCE HIGHER THAN EXCEPTED
2186-IDLE SPEED PERFORMANCE LOWER THAN EXCEPTED
2189-IDLE SPEED AT START UP IS TOO HIGH
2190-IDLE SPEED AT START UP IS TOO LOW
2193-O2 SENSOR 1/1 CIRCUIT/OPEN
2197-O2 SENSOR 2/1 CIRCUIT/OPEN
2229-FUEL LEVEL SENSOR 1 PERFORMANCE
2230-FUEL LEVEL SENSOR 1 PERFORMANCE
2232-FUEL LEVEL SENSOR 1 PERFORMANCE
2234-MANIFOLD ABSOLUTE PRESSURE SENSOR PERFORMANCE
2269-FUEL TANK PRESSURE IS TOO HIGH
2270-FUEL TANK PRESSURE IS TOO LOW
2297-FUEL TANK PRESSURE SENSOR CIRCUIT PERFORMANCE
2301-FUEL PUMP CONTROL CIRCUIT/OPEN
2305-O2 SENSOR 1/1 SLOW RESPONSE
2307-O2 SENSOR 1/1 SLOW RESPONSE
2309-O2 SENSOR 2/1 SLOW RESPONSE
2311-O2 SENSOR 2/1 SLOW RESPONSE
EVENT 0113-STOP LAMP - SIGNAL IMPLAUSIBLE
EVENT 0925-ENGINE CAN BUS - THE VEHICLE SPEED SIGNALS OF THE FRONT AXLE ARE IMPLAUSIBLE
EVENT 0929-ENGINE CAN BUS - PLAUSIBILITY ERROR OF VEHICLE SPEED SIGNAL VIA CAN
EVENT 0931-ENGINE CAN BUS - PLAUSIBILITY ERROR OF VEHICLE SPEED SIGNAL VIA CAN
EVENT 1289-(STOP LAMP SWITCH) - ERROR ON TRANSMITTING MESSAGE
EVENT 1405-TRANSMISSION CONTROL UNIT - ERROR ON TRANSMITTING MESSAGE
1409-EVENT TRANSMISSION CONTROL UNIT - ERROR ON TRANSMITTING MESSAGE
EVENT 1421-TRANSMISSION CONTROL UNIT - TORQUE REQUEST FROM DRIVE SOFTWARE NOT PLAUSIBLE
EVENT 1605-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1609-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1613-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1617-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1621-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1625-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1633-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1637-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1641-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1665-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1669-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1673-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1677-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1681-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1685-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1689-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1693-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1697-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1701-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1705-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1709-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1713-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1717-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1721-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1725-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1729-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1733-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1737-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1741-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1745-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1749-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1753-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1761-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1765-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1769-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1773-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1777-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1781-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1785-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1789-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1793-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1797-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1801-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1805-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1809-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1813-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1817-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1821-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1825-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1829-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1833-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1837-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1841-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1845-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1849-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
EVENT 1853-FAULT PRESENT IN TRANSMISSION CONTROL MODULE
