Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
my srs light is on can any one help plz...
Old 11-07-2008, 10:31 AM
93stealthes's Avatar
93stealthes
93stealthes is offline
Default my srs light is on can any one help plz...
my srs light is on and i dont no y, i checked the seatbelt plugs under both seats and they are both connected, my breakes need changed could that be a issue, and i have another ques, when my car is at normal running temp when i turn it off it will not turn over for anything, i have to wait till the motor cools down, i was told that it could be a spark problem...
any help would be very much appreciated...
Old 11-07-2008, 01:36 PM
yevgenievich's Avatar
yevgenievich
yevgenievich is offline
srs is your air bag, most people just ignore it or pull the bulb out. There are many reasons it could be on and causes a lot of headaches trying to fix it. As far as motor not turning, just a thought but do you have any white smoke out of your exhaust?
Old 11-07-2008, 03:22 PM
93stealthes
o ok would i be able to scan it to see y it is on or would that not work cuz i really dont feel like driving down the road and outta no where get blasted with a 200 mph bag of air i believe that would hurt a lil, and no none that i can see but my check engine light is on but my car runs as good as it did when i bought.
Old 11-08-2008, 08:31 PM
yevgenievich
if your check engine light is on, stop by auto part store like Oreilly and they can scan it for free. As far as airbag if something is really wrong with it it's just not going to open.
straight from the wiki about srs light:
Things that can cause the SRS light to turn on include:
  • Letting battery drain too low
  • Bad Sensor
  • Blown fuse
  • Unplugging the car’s battery
  • Removing the gauge cluster/installing aftermarket gauges
  • G-Force sensors that are under each of the front fenders ($250.00 each)
  • Bad clockspring (located inside your steering wheel)
  • Bad ECU
  • Bad reverse light switch on transmission
  • Car was in an accident
  • Airbag defective/unplugged
check this sites:
http://www.wrenchmonkey.com/Webpages/DRB.html
also turning your ignition key 10 times might fix it.(not starting, but just turning on the accessories)
Old 11-10-2008, 08:45 AM
93stealthes
ok thank u i appreciate it
Quick Reply: my srs light is on can any one help plz...
