1998 Stratus Wont Start with Code P0340
Hello all. We have a 1998 Dodge Stratus 2.4l 4Cyl. that all of the sudden won't start. After a drive one day it was parked outside over night in the driveway. The next day the car would not start.
After some testing I found that:
-we have spark
-fuel pressure is good
-starter is good
-fuel pump is fine
-fuel filter is fine
-spark plugs are brand new after replacing just recently
-battery is good (brand new)
-fuel injectors are good
-we are getting the following info from an OBD2 Reader
code: P0340
Camshaft Position Sensor A Circuit (Bank 1 or Single Sensor)
-Freeze Frame Data-
Fuel System 1
Open Loop
Calculated Load
0.00%
Engine Coolant Temp
39 Degrees F
STFT Bank 1
0.00%
LTFT Bank 1
0.00%
Intake Manifold Pressure
29.8 in.hg
Engine RPM
000 RPM
Vehicle Speed
0 MPH
I'm not sure if we should go about jumping into replacing the camshaft position sensor or where to start. I can't afford to have it towed to a technician at the moment...Any ideas? Your help is much appreciated in advance. Thank You!
-we have spark
-starter is good
-fuel pump is fine
code: P0340
-Freeze Frame Data-
Fuel System 1
Open Loop
Calculated Load
0.00%
Engine Coolant Temp
39 Degrees F
STFT Bank 1
0.00%
LTFT Bank 1
0.00%
29.8 in.hg
Engine RPM
000 RPM
Vehicle Speed
0 MPH
