03 dodge stratus R/T....dashboard replacement....and any other help i can get
Just got a 03 stratus R/T v6 auto it has a heat destroyed dash it's folding and lifting looking to see if anyone knows a way to fix cheap or a replacement parts dealer or what to do.....I'm in Orlando FL ...and would love to get some knowledge on this car any major issues I should look for also the car has a mild humming sound when pulling away from a stop the previous owner said he had a tranny mount replacement done and it has been there since.......any defects know on this car should I change anything should I replace anything asap.........please help me I would like to try to do most of the work on her by myself.......
Parts are expensive, as you have a Mitsubishi vehicle built by Diamond Star. It's about as much Dodge as a Ford Escort.
Al in all they were pretty reliable as long as you maintained things like plugs, wires, cap, rotor and timing belt.
Those dashes do that. It's a full dash pull and dissection to replace it. I would bet that is a discontinued part by now. You can call a dealer and ask though.
The dashboard problem was discussed a month ago, just glue it- https://dodgeforum.com/forum/dodge-s...eparation.html
As for the motor mounts, I, and along with many other Stratus Coupe owners had to replace them because they break apart. There are nice solid mount inserts available. Need parts mechanically? You own a 2003 Mitsubishi Eclipse GT.
