Center counsole removal
this might help its for an '04 should be close
REMOVAL
(1) Raise parking brake lever as high as possible.
(2) Move transmission shifter to neutral position.
(3) Loosen set screw on front of shifter **** and
remove shift lever ****.
(4) Remove lighted transmission range indicator
letter bezel (Fig. 8).
(5) Disconnect transmission range indicator bezel
wire connector at the shifter mechanism.
(6) Remove screws, next to floor shifter and in console
storage compartment, attaching floor console to
brackets on floor pan (Fig. 9).
(7) Disconnect wire connector for floor console
accessories at floor pan.
(8) Remove console from vehicle.
NOTE: The grip portion of the parking brake lever
will only fit through the wider lower portion of the
slot in the floor console.
INSTALLATION
(1) Position console in vehicle.
(2) Connect wire connector for floor console accessories
at floor pan.
(3) Verify that the rear locator pin on the bottom
of the storage bin is engaged to the slot in the body
bracket and the front pin is engaged to the shift
mechanism (Fig. 8).
(4) Install screws, next to floor shifter and in console
storage compartment, holding floor console to
brackets on floor pan.
(5) Connect transmission range indicator bezel
wire connector on shifter mechanism.
(6) Install lighted transmission range indicator letter
bezel.
(7) Install shift lever **** and tighten set screw
on front of shifter ****.
REMOVAL
INSTALLATION
at floor pan.
mechanism (Fig. 8).
bezel.
