tach runs in reverse
Old 07-04-2015, 10:38 PM
tmomeik's Avatar
tmomeik
tmomeik is offline
Default tach runs in reverse
I have a 1999 Stratus with a 2.4 that the tach runs from 0 to 7000 with the needle running counter clockwise. I replaced the input and output sensors thinking they were the wrong ones. What else would cause this? The speedometer is working correctly.
Old 07-05-2015, 09:35 AM
BillS's Avatar
BillS
BillS is offline
most likely you need a new instrument cluster seemed to be a problem with circuit board soldered connections,you can try self testing gauges push and hold trip meter button turn key on hold for two seconds let gauges run test see if it works
Old 07-05-2015, 10:10 AM
tmomeik's Avatar
tmomeik
tmomeik is offline
Yes I have already tried that, but it didn't work. The other issue is the car is stuck in limp mode, and I have already replaced the input & output speed sensors and the control solenoid, but something in the back of my mind keeps telling me to get the tach issue resolved first.
Old 07-05-2015, 12:43 PM
BillS's Avatar
BillS
BillS is offline
is your engine light on any codes showing lot of places like auto zone or advance will read them for free
Old 07-05-2015, 12:47 PM
tmomeik's Avatar
tmomeik
tmomeik is offline
I do get the P0733 code, but even just reseting doesn't help, even after putting in the new parts
Old 07-05-2015, 05:16 PM
BillS's Avatar
BillS
BillS is offline
have you changed the fluid and filter have seen several posts on here that stratus transmission problems can be caused by dirty filter or fluid
Quick Reply: tach runs in reverse
