2001 status motor mounts
Hi everyone, just had a quick question. I had all for motor mounts replaced on my 2001 2.4l stratus se coupe and the engine is shaking even more than before I had them replaced. They were replaced with after market parts by a certified mechanic. Is this normal after replacing these parts? Should I drive for a bit to break them in? Any help would be greatly appreciated!
Full motor mounts though? I had never heard of that brand, but googled it and the entire mounts showed up on eBay. OEM style.
The balance shaft belt is behind the timing belt towards the bottom of the engine. I dont know if mine was bad, but I was prepared for a little bit of shaking when I did the stiffer mounts. It only shakes at idle.
Ive heard of the balance shaft belt snapping and not affecting the engine much, just vibrations.
