Dodge SRT-10 Ram *pics 56K war
Old 03-23-2003, 05:18 PM
Shogunn's Avatar
Shogunn
Shogunn is offline
Default Dodge SRT-10 Ram *pics 56K war
heres some news, specs andpics on it</P>
<TABLE borderColor=black cellSpacing=0 cellPadding=4 width=500 border=1>
<TBODY>
<TR>
<TD width="50%">Price:</TD>
<TD>$--,---</TD></TR>
<TR>
<TD>Miles Per Gallon:</TD>
<TD>--/-- mpg</TD></TR>
<TR>
<TD>Curb Weight:</TD>
<TD>5000 lbs</TD></TR>
<TR>
<TD>Layout:</TD>
<TD>Front-Engine/RWD</TD></TR>
<TR>
<TD>Transmission:</TD>
<TD>6-Speed Manual</TD></TR>
<TR>
<TD align=middle bgColor=#848484 colSpan=2><FONT color=#000000 size=5>Engine</FONT> </TD></TR>
<TR>
<TD width="50%">Type:</TD>
<TD>V10</TD></TR>
<TR>
<TD>Displacement:</TD>
<TD>8300 cc</TD></TR>
<TR>
<TD>Horsepower:</TD>
<TD>500 bhp @ 5600 rpm</TD></TR>
<TR>
<TD>Torque:</TD>
<TD>525 lb-ft @ 4200 rpm</TD></TR>
<TR>
<TD>Redline:</TD>
<TD>6000 rpm</TD></TR>
<TR>
<TD align=middle bgColor=#848484 colSpan=2><FONT color=#000000 size=5>Performance</FONT> </TD></TR>
<TR>
<TD width="50%">0-60 mph:</TD>
<TD>5.2 sec</TD></TR>
<TR>
<TD>0-100 mph:</TD>
<TD>11.5 sec</TD></TR>
<TR>
<TD>Quarter Mile:</TD>
<TD>13.8 sec @ 106 mph</TD></TR>
<TR>
<TD>Skidpad:</TD>
<TD>.--g</TD></TR>
<TR>
<TD>Top Speed:</TD>
<TD>150 mph</TD></TR>
<TR>
<TD>Braking, 60-0 mph:</TD>
<TD>--- ft</TD></TR>
<TR>
<TD>Slalom Speed:</TD>
<TD>--.- mph</TD></TR></TBODY></TABLE></P>
The 2004 Dodge Ram SRT-10 is built for speed. With a top speed of 150 mph and the biggest engine in a performance pickup, the Dodge Ram SRT-10 backs up its claim as the baddest truck on the block.
More than just a big engine, Ram SRT-10 adds the largest standard wheels and tires, the largest brakes in its class and acceleration to match its macho looks. Unique in a world of look-alike trucks, the Ram SRT-10 is a radical, custom-built performance truck, but straight from a manufacturer and with performance cues direct from the Dodge Viper SRT-10, the ultimate sports car.
Absolute Power = Absolute Domination
From the beginning, the engineers at Performance Vehicle Operations knew the powertrain was in place. The 8.3-liter Viper V-10 was upgraded for 2003 with a new bored and stroked aluminum engine block that increased the Viper engine's displacement from 488 to 505 cubic inches, and pushed its V-10 power output to 500 horsepower and 525 lb.-ft. of torque.
Resting on unique engine mounts, the new V-10 engine delivers 90 percent of its whopping 525 lb.-ft. of torque from 1500 to 5600 rpm. The all-new cast aluminum cylinder block has interference-fit cast-iron liners and cross-bolted main caps. Both bore and stroke have been increased over previous Viper models. Block length, block height, bore spacing, firing order, rod length and compression ratio are unchanged.
The Viper V-10 includes a six main bearing crankshaft with increased stroke length and cross-bolted main bearing caps. All-new cast aluminum alloy pistons - weighing slightly less than prior years despite larger diameters - are included, as are all-new cracked-steel connecting rods that are lighter yet stronger.
Cylinder heads on the Viper V-10 are redesigned using semi-permanent mold (SPM) 356 T6 aluminum, with improved intake port, exhaust port and combustion chamber cooling. Lower-profile die-cast magnesium cylinder head covers with steel internal baffles and anti-slosh foam also are new for 2003.
A single-piece, central dual-plenum, cast aluminum intake manifold is also new. It boasts shorter runners and a single, non-staged two-barrel throttle body for higher peak horsepower RPM. The intake manifold is an all-inclusive Integrated Air and Fuel Module (IAFM) with tubular fuel rails, injectors, sensors, wiring and throttle body - delivered assembled and pre-tested.
A Ram Heavy Duty cooling system is modified to handle the needs of the new Viper engine. A custom dual exhaust system is mounted to new exhaust manifolds.
The 2004 Dodge Ram SRT-10 focuses its power through a new Hurst shift linkage and a modified version of the Viper SRT-10's Tremec T56 six-speed manual transmission. The T56 is fully synchronized with electronic reverse lockout. A new driveshaft runs to the Viper-sourced transmission and a modified differential with a 4.10 rear axle delivers the torque to the road.
Suspension
The Ram SRT-10 is more than just a big Viper motor in a bad-*** truck. The engineers at PVO modified the Ram Heavy Duty's rack-and-pinion steering and independent front suspension.
Working with the fully hydroformed Dodge Ram frame, one of the stiffest in the industry, PVO added a custom tuned suspension, dropping the Ram SRT-10 one inch at the front and two inches at the rear. New front and rear strut assemblies and a rear sway bar were added to handle the increased cornering loads.
Next came Bilstein shock absorbers, performance-tuned springs, unique aerodynamic aids to enhance the Ram SRT-10's higher speed performance, and 22-inch custom "Viper-style" wheels and 305/40 Pirelli Scorpion Tires.
Big brakes, another Dodge Ram staple, are also part of the equation on the 2004 Ram SRT-10. The standard ABS-equipped brakes are fitted with new 15-inch rotors on the front brakes. Rear brakes are modified Ram Heavy Duty 14-inch rotors. Front and rear brakes feature unique red calipers. The new front fascia features brake ducts to provide plenty of cooling for track sessions.
Features
The most noticeable exterior feature of the new 2004 Dodge Ram SRT-10 is a unique hood that features a wide power bulge and scoop sitting atop the signature cross-hair grille. "Viper Powered" badges on either side of the hood scoop leave no doubt as to what resides underneath.
Keeping things simple, the Dodge Ram SRT-10 is available in black, red and silver only. The updated Ram lines of the Ram SRT-10 provide a look of machined elegance with a lower - and even bolder - stance than the standard Ram. The Ram SRT-10 rides on unique 22-inch polished aluminum "Viper-style" wheels, the largest wheels available on production pickup.
The new front fascia, unique hood with integrated air intake, billet grille, lower ride height and ground-effect moldings provide plenty of "hunkered down" attitude even before the red ignition button is punched.
From the side, an aluminum fuel filler, unique SRT-10 badging and red brake calipers visible behind the 22-inch wheels distinguish the Dodge Ram SRT-10. The rear spoiler, custom rear fascia with cutout for dual exhausts and large, center-mounted chrome Ram's head badge provide the view for the majority of the motoring public.
"There is a slightly understated air about the SRT-10, especially considering its performance potential," said Rick Aneiros, Vice President, Truck Design. "But as powerful as the overall theme of the Ram SRT-10 is, we were determined not to make this another boy racer truck. We added functional aero tweaks to deliver a truck that can handle 150 mph-plus speeds. Its true design identity is found in the unique details, such as the red brake calipers visible behind the new 22-inch wheels, the mesh grille covering the air intakes and the lowered stance. The SRT-10 is instantly recognizable as something different from Ram, more powerful but with subtle detailing. It means business."
Inside, heavily bolstered racing-derived leather seats with black suede perforated inserts and a carbon-fiber leather trim steering wheel let drivers know this is no ordinary Ram. The "SRT-10" logo is embroidered on the headrests. Silver trim adorns the center stack and a silver trim strip with an "SRT-10
Quick Reply: Dodge SRT-10 Ram *pics 56K war
