throttle bodies
RE: throttle bodies
Most instructions tell you to remove the battery negative before working on anything, but mainly anything that deals with any electrical at all. The throttle body has sensors and they are an electrical component, disconnecting the battery guarantees that they do not get damaged by the connecting or disconnecting of the electrical plugs/connectors.
RE: throttle bodies
the other thing about disconnecting the battery is everytime you do an upgrade to the motor like a chip or tb after you reconnect it. start and stop motor 3 times. on the 3rd time leave truck running for a couple of minutes so the computer can recalibrate itself do to the upgrade
