Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
no side tail lights when headlights are on
Old 01-24-2017, 04:35 PM
gwl99's Avatar
gwl99
gwl99 is offline
Default no side tail lights when headlights are on
when the headlights are on the back blinker. tail lights, and flashes don't work. when the headlights are off they all work fine. i have checked ALL the fuses and as far as i know checked all the relays by switching each on around with another similar relay
Old 01-25-2017, 11:43 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Check grounds.
Old 03-18-2017, 02:32 PM
Carl_S's Avatar
Carl_S
Carl_S is offline
Check the turn signal switch. Had that problem on an 85 Ramcharger and found the turn signal switch was bad.
Quick Reply: no side tail lights when headlights are on
