Dodge Nitro The Dodge Nitro is a sporty mid size SUV that bound to turn heads where ever it roams. The Dodge Nitro is one fun ride!
window washer has low pressure
Old 12-04-2016, 09:33 PM
blades33's Avatar
blades33
blades33 is offline
Default window washer has low pressure
I have changed the pump next to the washer fluid tank. The rear window washer flows. I unhooked the hose to the hood nozzles and have flow. I put in new nozzles. When I put on the washer the fluid just makes it to the bottom of the windshield. I put in new pump and nozzles and I don't see any blocked hoses, so why is the pressure low?
Old 12-05-2016, 09:28 AM
primem's Avatar
primem
primem is offline
low supply voltage or resistance on the grd circuit will cause the pump to spin slower than normal and not develop pressure.
