Which 2014 R/T Is Best?????
So i have been looking to get a used 2014 dodge charger r/t but always stumble upon different types of r/t. Ive come across the 100th year anniversary, road and track and r/t plus. I just was wondering what the exact didference is between all the r/t models and which one is best to get?
14 rt plus
ive got the 14 rt plus, 48k miles, and have had an alignment issue (out of alignment from factory dealer added 2 extension kits) and recently the oil pressure sensor pegged so got it replaced. I bought it new and still love driving it. Plenty of bells/whistles. I would recommend.
Yeh, the trims can vary and are many.
Make a list of when you MUST have and go shopping.
My priorities were:
2013 minimum to avoid the timing chain recall.
Not over 70k miles.
Clean, Clean, Clean.
R/T (HEMI)
Granite Crystal Met color
No spoiler
That was it. I found an R/T Plus.
Here is the build sheet.
Just a note. I have heated seats, To get heated steering wheel you would have to move up to the MAX. Thats how things go.
As you can see I got more them my must have priorities.
Sales Code Description
BL Sport Leather Seats
X9 Black
APAS Monotone Paint
BADP 180 Amp Alternator
BCNS 730 Amp Maintenance Free Battery
BGES Brake Assist
BHCS Rain Brake Support
BHDS Ready Alert Braking
BNBS Electronic Stability Control
BNGS Hill Start Assist
BNPP All Speed Traction Control
BPTS Hydraulic Assist Brake Booster
BR5S Anti-Lock 4-Wheel Disc Perf Brakes
BTBP All Vehicles w/ABS Brakes
CBDS Active Head Restraints
CDMP Leather Trim Seats
CFNS Rear 60/40 Folding Seat
CF4S Child Seat Upper Tether Anchorages
CGDS Front Height Adjust Shoulder Belts
CG3S Advanced Multistage Front Air Bags
CG6S Center Rear 3-Point Seat Belt
CJ1S Supplemental Frt Seat Side Air Bags
CJ2S Supp. Side Curtain Frt/Rr Air Bags
CKDS Floor Carpet
CKMS Cargo Compartment Dress-Up
CKRS Cargo Net
CKUS Decklid Liner
CLZS Front & Rear Floor Mats
CSNP Rr Armrest w/Cupholder Seat
CSRS Passenger Assist Handles
CSSS Illuminated Rear Assist Handles
CUFS Full Length Floor Console
CVKS Cell Phone Storage
CVWS Leather Wrapped Shift ****
CWPS Illuminated Front Cupholders
CXNS Part Tracking
DGJ 5-Speed Auto W5A580 Transmission
DHDP AutoStick (R) Automatic Transmission
DLCS 2.65 Rear Axle Ratio
DPPS 215MM Rear Axle
EZH 5.7L V8 HEMI MDS VVT Engine
GAKS Acoustic Windshield
GAMS Solar Control Glass
GAPS Acoustic Front Door Glass
GBCS Front & Rear Solar Control Glass
GFAS Rear Window Defroster
GNCS Sun Visors w/Illum Vanity Mirrors
GN5S RR View Auto Dim Mirror w/Microphone
GUKS Power Heated Mirrors w/Man F/Away
GXDS Remote Proximity Keyless Entry
GXTS Rear Door Child Protection Locks
GXXS Sentry Key Theft Deterrent System
GX4S Keyless Go
HAFS Air Cond ATC w/Dual Zone Control
JAAS Instrument Panel
JAYS Instrument Cluster w/Tach
JCCS 160 MPH Primary Speedometer
JFAS Compass Gauge
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JKDP Remote Fuel Door Release
JKKS Inside Emergency Trunk Lid Release
JKWS 12V Center Console Power Outlet
JKYS Power Accessory Delay
JMAS Air Filtering
JPCS Power Trunklid Release
JPHS Speed Sensitive Power Locks
JPMS Heated Front Seats
JPTP Power Front Driver/Passenger Seats
JPZP Heated Second Row Seats
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRNP Pwr Driver/Pass 4-Way Lumbar Adjust
LAHS Outside Temp Display
LATS Custom Defined Color Display Monitor
LAXS Front Passenger Seat Belt Alert
LBCS Glove Box Lamp
LBGS Front Reading/Map Lamps
LBHS Rear Reading/Courtesy Lamps
LBLP Driver & Passenger Lower LED Lamps
LBTP Front Overhead LED Lighting
LBUS Front & Rear LED Map Pockets
LDCS Trunk Lamp
LEPP Body Color Exterior Mirrors
LMGS Automatic Headlamps
LMKS Daytime Running Headlamps, High Beam
LM4S Bi Fnct HID Projector SRT Headlamps
LNJS Projector LED Fog Lamps
LPAS CHMSL Lamp
LSAP Security Alarm
MFAS Black Headlamp Bezels
MFMS Black Grille w/Bright Surround
MNKS Body Color Door Handles
MRCS Bodycolor Lower Bodyside Cladding
MSWS R/T Badge
MT1S Charger Badge
MW5S Hemi Badge
MX8S No Rear Spoiler
NAS 50 State Emissions
NEAS Performance Exhaust
NELP Dual Bright Exhaust Tips
NERS Dual Rear Exhaust
NGAS 19.1 Gallon Fuel Tank
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NMBS Standard Duty Engine Cooling
NZES Base Engine Controller
PAU Granite Crystal Met. Clear Coat
QAUS Granite Crystal Met. Clear Coat
RCJS 6 Premium Speakers
RDLS Integrated Window Antenna
RDZS Steering Wheel Mounted Audio Ctrls
RD7S 276 Watt Amplifier
RE2S Radio 8.4
RFLP 8.4" Touchscreen Display
RSCP SIRIUS Satellite Radio
RSLP Bluetooth Streaming Audio
RSPS Uconnect Voice Command w/Bluetooth
RSUP Audio Jack Input for Mobile Devices
RSXP Remote USB Port
SBAS Power Rack and Pinion Steering
SCVS Leather Wrapped Steering Wheel
SDDS Sport Suspension
SUDS Tilt/Telescope Steering Column
TBCS Compact Spare Tire
TWNS P235/55R18 BSW AS Perf Tires
TZHP Michelin Brand Tires
WLZC All Aluminum Wheels
WPLP 18X7.5 Aluminum Chrome Clad Wheels
XA8S Non Adjustable Pedals
XBMS Remote Start System
XBNS Tip Start
XGAP Front/Rear Climate Control Outlets
XGDS Universal Garage Door Opener
XGMS Tire Pressure Monitoring Display
XGYP Heated/Cooled Frt Console Cupholder
XJMS Capless Fuel Filler
XKDS 'Why Buy' Label
XLNS English/USA Language
XSLS Brake/Park Interlock
XSSS Woven Micro Alum Interior Accents
XXKS Electro-Hydraulic Power Steering
XXTP Humidity Sensor
X8XS Brake & Knuckle Parts Module
X81S Instrument Panel Parts Module
X82S Door Parts Module
X84S Front Suspension Parts Module
X85S Rear Suspension Parts Module
X87S Power Train Parts Module
X88S Tire & Wheel Parts Module
X89S Front Suspension Damper Parts Module
X9BP 1-Yr. SiriusXM Radio Service
X91S Rear Suspension Damper Parts Module
YAAS Build To U.S. Mkt. Specifications
My priorities were:
Not over 70k miles.
R/T (HEMI)
No spoiler
X9 Black
APAS Monotone Paint
BGES Brake Assist
CKDS Floor Carpet
CKRS Cargo Net
CKUS Decklid Liner
CXNS Part Tracking
GX4S Keyless Go
JFAS Compass Gauge
JMAS Air Filtering
LBCS Glove Box Lamp
LDCS Trunk Lamp
LPAS CHMSL Lamp
LSAP Security Alarm
MSWS R/T Badge
MT1S Charger Badge
MW5S Hemi Badge
NHMS Speed Control
RE2S Radio 8.4
XBNS Tip Start
