Help me figure out this leak
Old 02-24-2017, 03:41 PM
MrTouchy's Avatar
MrTouchy
MrTouchy is offline
Default Help me figure out this leak
I have a leak that is kind of wattery oil or coolant. I see where the leak is originating but am not familiar enough with engines to describe it. Can someone please tell which gasket this is by these pictures? It's a 2008 1500 4x4 5.7 hemi.
Attached Thumbnails Help me figure out this leak-20170224_132757-1-.jpg   Help me figure out this leak-20170224_132738-1-.jpg   Help me figure out this leak-20170224_132720-1-.jpg   Help me figure out this leak-20170224_132647-1-.jpg   Help me figure out this leak-20170224_132637-1-.jpg
Old 02-24-2017, 07:34 PM
p38251's Avatar
p38251
p38251 is offline
Looks like the water pump might be leaking.
Old 03-12-2017, 03:18 PM
Chrispickett12's Avatar
Chrispickett12
Chrispickett12 is offline
Touchy, Have you figured this leak out. I may have the same problem, 2005 dodge Ram daytona 5.7. Mine only leaks after it cools down overnight, and traces dry once I run it, with no leaks while running, then next night same thing. My water pump was replace less than a year ago as well as thermo.
Old 03-15-2017, 06:43 AM
Chrispickett12
touchy, I had a very similar leak, I thought it was coolant, only showed up in morning after setting, mine turned out to not be coolant, but simply a clogged ac drain line. The way it ran down it would look as though either the timing chain cover or the water pump gasket was leaking, it was not. get a cooling system pressure teser loan from autozone. Do this when engine is cold-it is very easy to use, pump it to 16-20 lbs, mine was 16. At that point if it is a cooling system leak it will show itself. If it is a water pump or timing cover leak, it is a straight forward job, if you know which way a wrench turns, there are many how to videos that will show how. When I did mine it took about 4 hrs with all hand tools. Hope this helps if you have not figured it yet.
Old 10-06-2017, 09:47 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Originally Posted by mrtouchy
i have a leak ........
omg that name roflmao !!!!
