Caliber SRT-4 This compact crossover combines high performance with the interior room of a small SUV.
Voltage@knock sensor connector
Old 03-11-2017, 05:19 PM
vicman's Avatar
vicman
vicman is offline
Default Voltage at knock sensor
Hi,
Does somebody know what is the voltage that a PCM froma Dodge Caliber '07 sends to the knock sensor?
I mean, if I disconnect the knock sensor, what is the voltage that I should read on the two wires connector using a voltage meter?
I am getting a very high ignition timing advance and I suspect that voltage is not righ. My car has very poor power and poor gas milleage.
Does somebody know what is the voltage that I should read with a voltage meter at the knock sensor connector? I mean, knock sensor disconnected, what is the voltage that the PCM send?
Old 03-29-2017, 02:45 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Here is a link to the factory service manual that you can download for free. It should have all of the info that you need. https://dodgeforum.com/forum/dodge-c...ce-manual.html
