1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Cigarette Lighter/Accessory Socket Fix
Old Apr 7, 2007 | 10:55 AM
DennisR's Avatar
DennisR
Default Cigarette Lighter/Accessory Socket Fix
Has your Lighter/Accessory socket quit working, yet the fuses. etc. are all fine? This just happened to me and a search of the forums showed several others with the same problem, but no solutions. So I took mine apart (95 Avenger ES) and here is what I found. *Diagram and picture included.*
The bottom of the socket has two positive (+) metal strips seperated by a non cunductive washer while connected with a small black wire that in actuality is a fusible link. It takes very little to blow this link. In my case, airing up a tire with a HD 12v compressor did it.One could replace the link (small and tedious...read fragile), orbuy a new socket from one of the various vendors or do as I did. I took the thing apart, removed the non-conductive washer and fusible link, tossed them and reassembled what was left to get a working socket. It's all still protected by the fuse so I feel safe enough with the results. As always, YMMV.
Good luck.
[IMG]local://upfiles/59161/9926838BEADA4C84B94A1372914F7BA3.jpg[/IMG]
Old Apr 7, 2007 | 12:06 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Cigarette Lighter/Accessory Socket Fix
Thanks for sharing that with us Dennis
Mine died at around 50k. I never tried to even fix it until around another 25k or so. My lighter was too caked up to use anymore, but the socket still charged my cell phone...do you have a fix for those lighters? Aside from not smoking, lol.
Old Apr 7, 2007 | 12:42 PM
DennisR's Avatar
DennisR
I've seen the lighter elements (they just unscrew from the top part) somewhere. Maybe check your local Autozone or Advance Auto Parts for them. It's been awhile since I looked for one, but remember that it wasn't hard to find.
Old Apr 7, 2007 | 01:01 PM
bad venge's Avatar
bad venge
Section Moderator
normally a good cleaning with a toothbrush followed by a good blowing out with an air nozzle will fix that
