1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Tech stuff
Old Apr 8, 2007 | 10:41 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: Tech stuff
Hey BV, if you have time, post these seperately so that I can sticky them in their own thread. Thanks for posting them too BV.[sm=smiley20.gif]
Old Apr 8, 2007 | 01:25 PM
rthegremlin2's Avatar
rthegremlin2
Wow!! Some great info! Thanks for posting it Bad Venge. I would still like info on engines and transmissions. I have figured out that the 2.0 is the 420a but beyond that I am not sure. I was also wondering if a 2.5 or 3.0 could fairly easily be put in place of a 2.0. Are there any major faults in the 5 speed transmissions? Again thanks for posting all the great info.
Old Apr 8, 2007 | 01:29 PM
bad venge's Avatar
bad venge
Section Moderator
Stereo wiring
Constant 12V+ Red
Switched 12V+ Blue
Ground Black/Yellow
Illumination n/a
Dimmer Green/Yellow
Antenna Left Rear
Front Speakers 6 3/4" Doors
Left Front (+) White/Blue
Left Front (-) Black/Blue
Right Front (+) White/Red
Right Front (-) Black/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Yellow/Blue
Left Rear (-) Gray/Blue
Right Rear (+) Yellow/Red
Right Rear (-) Gray/Red
Old Apr 8, 2007 | 02:02 PM
bad venge's Avatar
bad venge
Section Moderator
ORIGINAL: rthegremlin2
OK the 3.0 is a direct swap for the 2.5 ... It's a huge proposition to get the 2.5 into the 2.0...Also the V6 will NOT mate to the 5 Speed so you'll end up swapping in the Automatic tranny
Old Apr 8, 2007 | 02:50 PM
rthegremlin2
Are there any write-ups on doing the 2.5 into a 2.0 swap. I searched here for a 2.0 swap and didnt find anything interesting.
Old Apr 8, 2007 | 03:38 PM
bad venge's Avatar
bad venge
Section Moderator
As far as I can remember I've only seen it done ONCE and it wasn't really well documented so I don't know of any write ups
