1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
speedometer light!!!
Old Apr 8, 2007 | 07:02 PM
dynamiteplaya3's Avatar
dynamiteplaya3
Default speedometer light!!!
Hi i was just wondering if anyone knew how to change the lights behind the speedometer/dash lights or what ever they are called... what do you have to do to get into the dash?
Old Apr 8, 2007 | 07:24 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: speedometer light!!!
Put tilt all the way down ...
Two Phillips screws on top of the dash surround bezel ...
but a towel ect over the top of the steering wheel top, Carefully pull out on the bezel it'll remove
Then remove the four phillips screws around the dash cluster, pull straight out to unplug the cluster , flip over and you'll see the twist lock bulbs
Old Apr 8, 2007 | 07:36 PM
dynamiteplaya3
ok lol well i was just wondering cause i havea red venge and it looks kind of weird with orange lights and wanted to change it to a diff color.. oh and by the waybad veng about a month ago were u at the cleveland autorama... i saw an avenger that looked exactly like yours but im not sure if that was uim just curious
Old Apr 8, 2007 | 07:40 PM
bad venge's Avatar
bad venge
Section Moderator
Yes that was me at Autorama ..
Unfortunately the orange color is on the rear of the gauges the bulbs are clear ... Depending on color you might have to sand the color off the rear of the gauges
Old Apr 8, 2007 | 07:43 PM
dynamiteplaya3
oh ok nvm then... thats pretty sweet that u were there at autorama are u from around there??? and how much did u spend on all the upgrades to ur avenger? i was just wondering cause it looked like a pretty penny u spent lol
Old Apr 8, 2007 | 07:56 PM
bad venge's Avatar
bad venge
Section Moderator
I'm from Akron ...
Heres my Garage at another site ... It gives the mods list
http://aseclub.net/forums/index.php?...=12&CID=39
Old Apr 8, 2007 | 07:59 PM
dynamiteplaya3
sweet man im from a little town called randolph its about 30 mins from akron its close to alliance..
Old Apr 8, 2007 | 08:06 PM
bad venge's Avatar
bad venge
Section Moderator
Here's my list of Ohio shows
https://dodgeforum.com/m_766389/tm.htm
Old Apr 8, 2007 | 08:12 PM
dynamiteplaya3
sweet man do u drift in ur avenger?
Old Apr 8, 2007 | 08:28 PM
bad venge's Avatar
bad venge
Section Moderator
Drift is for rear wheel drive ....
I race at Mid Ohio sports car course and at several other drag strips throughout the season
