1995-2000 Dodge AvengerThe Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
cold air is closer to the ground to get more cold air away from the engine short ram is closer to the engine not sure of the hp gains from each probably similar i have a short ram cold air also sucks up water from puddles which will get into your engine
would it be a problem to drive in winter conditions with a short ram... will it suck up snow.... and if its really cold outside and you have a cold air/short ram, will it take longer for the engine to warm up since its pulling all that cold winter air into the engine... would you have to take it out during the winter months??
the main gain is from flow. i have a digital thermometer and actually checked the temperature of the air cleaner at the throttle body. try it, you'll be surprised.
