1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
fog light wireing
Old Apr 10, 2007 | 12:54 PM
aveng_95's Avatar
aveng_95
Default fog light wireing
Anyone know if all Avengers are wired for fog lights or was the wireing part of the option package. As i stated before i will soon be replacing the rad support in my Avenger. When i got the replacement rad support from the junk yard i also grabed the factory fog lights. The car allready has the fog light switch on the dash, I added that last year when i replaced the cruise control switch but did not notice ( or can't remember )if the wiring was in the dash.
Old Apr 10, 2007 | 04:46 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: fog light wireing
Your car should be wired for it already. The wires should be prerun to keep downtime to a minimum. Look for the wiring around the foglight opening and radiator framing. Do you see that white ziptie, that's my foglight wiring. Yours most likely won't be like that, but the pic is to give you a round about area.
Inside, the removable panel to the left of the instrument cluster area as seen in this pic.
Old Apr 10, 2007 | 07:19 PM
bad venge's Avatar
bad venge
Section Moderator
it's a crap shoot some are prewired some are not , some have wiring inside the car and others have just the outer underhood wiring ... no logic at all to this ...
Old Apr 11, 2007 | 01:28 PM
aveng_95's Avatar
aveng_95
well then that leaves me right back where i started . When i pull the front end of the car apart in a couple weeks to do the rad support i'll look for the wires and if there not there i'll get the factory harnes to add or run new wiring thru a relay then to the switch. Thanks for your time guys.
