1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Same Old Problem With Dying At Idle
Old Apr 21, 2007 | 12:32 AM
Goose's Avatar
Goose
Default Same Old Problem With Dying At Idle
Ok, I changed the rotor, dist. cap, plugs and wires and still the same problem. Has trouble starting, and once it does, it idles really rough. Once i drive it, it dies before I back out of the driveway. Then it takes several starts before it goes again, and dies berofe I'm back in the garage. Obviously still dies at idle. What gives?
Old Apr 21, 2007 | 12:56 AM
bad venge's Avatar
bad venge
Section Moderator
Default RE: Same Old Problem With Dying At Idle
Any CEL's ??? Codes ???
Old Apr 21, 2007 | 01:10 AM
Goose's Avatar
Goose
Yeah, P0206, Injector Circuit/Open Cylinder 6, and now it won't start at all. Turns over, and wants to start, but just wont.
Old Apr 21, 2007 | 01:29 AM
bad venge's Avatar
bad venge
Section Moderator
CPS would be a good guess
Old Apr 23, 2007 | 10:15 AM
MoPaul's Avatar
MoPaul
i would say take a look at the injectors, personally. a lot of crappy gas out there.
Old Apr 24, 2007 | 07:23 PM
josef15111's Avatar
josef15111
Im leaning towards the PCM mine was doing this same thing almost. It did the whole not start and really bad up and down idling i had to stay on the gas to keep it running. I changed my PCM and bam! it was fixed.
Hope it helps Joe
Old Apr 25, 2007 | 08:12 AM
Goose's Avatar
Goose
Alright, thanks, I'll chek that out and see how it works.
Old Apr 26, 2007 | 08:19 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
I agree with the crank angle sensor. It's below the distributor. It will give the same issues that you're getting. Other things to check is the ASD relay also. The Cam angle sensor in the distributor is one of the last things I would change because those don't commonly go bad.
Here's how I would go about it....
- ASD relay
- CPS
- PCM
- Cam angle sensor
The CPS also sends the signal for when the plugs spark and when the injectors pulse.
