1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Code P0300 and P0304
Old May 1, 2007 | 11:09 PM
rthegremlin2's Avatar
rthegremlin2
Default Code P0300 and P0304
Okhere is the situation, when I bought my car a few weeks agoit had a code for bad cam/crank sensors (11 i think it was with the key dance) so I replaced both of them just to be safe and the code went away. Now that i have that fixed I have p0304 and p0300. I have checked the spark and it is getting good spark, I swapped the plug with a different one. I cleared the codes and they came right back after a few minutes of running. So I checked to make sure the injector isworking and it has its tick. I also checked the resistance of the plug wire and I also tried swapping the wire from a different cylinderjust to make sure that it is not the wire. The only other thing I can think of is the injector is not passing fuel. Also when I pulled the plug in cylinder 4 it had a white deposit on it, not the blistery white like an overheated plug, more like the carbon buildbut white instead of black. So before I go and change the injector is there anything else I can check? Also does anyone know of an easy whay to change the injectors? By the way I have a 96with a 2.0. One other thing i forgot to mention is when I pull the plug wire while it is running the idle does not change, it arcs on the valve cover as i pull it out but no change in idle speed or quality.
Old May 2, 2007 | 02:55 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Code P0300 and P0304
I would say the cylinder head may need to come off. P0300 is a multi misfire and P0304 is number 4 misfire. So you may have a valve problem with number 4.
Old May 2, 2007 | 05:28 AM
Goose's Avatar
Goose
I had the same problem just after I changed my fuel filter. I just lived with it for a few days, and it went away all on its own. It's been several months and no such code since.
Old May 2, 2007 | 09:36 PM
rthegremlin2
Well a new update, I still have the same codes but I did a compression test and cylinder 1,2, and 4 are all at about 200 give or take a few but 3 is at 90. I added a little oil to the cylinder and I went upto 180 so I am going to guess that it needs rings for some reason.
