1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Coil pack
Old May 6, 2007 | 03:44 PM
sq89's Avatar
sq89
Default Coil pack
I have a 1995 Avenger ES and I can't seem to locate where the coil pack is, I don't have the original manual for it, and the Haynes book doesn't really help me out. Anyone know?
Old May 6, 2007 | 03:55 PM
JokerzVeng's Avatar
JokerzVeng
Default RE: Coil pack
do you have the 2.5 or the 2.0?...the 2.0 (on my 98 newayz) is right on top u cant miss it..
not sure bout the 2.5 v6 tho..;(
but the 2.0 is right on top of the valve cover
well it appears that the 2.6 v6 runs an actual distributor.so i guess it has an external coil ..just follow the coil wire..
Old May 6, 2007 | 10:00 PM
blackvenge34's Avatar
blackvenge34
yea the 2.0 is right on top it has 4 wires coming out that leads right to the spark plugs i got a new msd coil pack worked great and my car revs higher as well i have the 2.0 5spd
Old May 6, 2007 | 10:23 PM
sq89's Avatar
sq89
Ah my bad, I didn't even think of listing it, lol. I have the 2.5 V6 Automatic.
Old May 6, 2007 | 11:31 PM
blackvenge34
i think you have a distributer not really sure i would say follow the spark plugs cuz thats how it is for me with the 2.0 but im not sure
Old May 6, 2007 | 11:47 PM
JokerzVeng's Avatar
JokerzVeng
read my post above about the*2.5*..lol...the wire that doesnt run to a plug would b ur coil wire..
Old May 7, 2007 | 12:39 AM
josef15111's Avatar
josef15111
on the 2.5 you dont have a coil pack exactly, Its in your distrbuter so you have to get a new distrbuter if it goes bad.
Old May 7, 2007 | 08:51 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Right, the I4 is the distributorless motor and the V6 is the one with a distributor.
The V6 is under the intake pipe, so you'll have to remove the intake pipe to get to it.
As said above, the coilpack is on top of the valve cover, you can't miss it. It's the one with the spark plug wires coming out of it on either side (for future referrence to the I4 guys).
Old May 7, 2007 | 06:07 PM
2BlueGuyz's Avatar
2BlueGuyz
V6 2.5 - I'm researching the coil/distributor right now myself. I have 1996 ES that won't start. The coil is integrated into the distributor as stated above it is on the drivers side below the intake manifold. I have tested for fuel flow and thats good. I have done a rudimentary test for spark (pulled the wire and cranked looking for a spark to no avail) so now I need to refine that a bit. Luckily my car died in the driveway, but to get it to a garage to have it looked at means paying for a tow, so I'll spend a few days trying to figure out whats wrong first.
Old May 7, 2007 | 06:49 PM
silvercoupe97
Uber Moderator
Hi there 2BlueGuyz, welcome to DF.
If you could make a new thread with your post ^ in it, that way your issue can be focused on.
Just copy and paste and I'll delete this post later once you have made a new one. Thanks.
