1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
How do you replace bad valve seals?
Old May 14, 2007 | 05:22 AM
Nelson9937955's Avatar
Nelson9937955
Default How do you replace bad valve seals?
I was told i have some bad valve seals which is causing smoke to come out of exhaust. Could someone give me info on how much this will cost and directions on how to do it? Is it too complicated for a novice?
Old May 14, 2007 | 03:12 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: How do you replace bad valve seals?
I4 or V6 ???
Old May 14, 2007 | 03:54 PM
Nelson9937955
v6
Old May 14, 2007 | 04:15 PM
JokerzVeng's Avatar
JokerzVeng
to do it still on the car u will need a modified spark plug(the threaded part) made into an air chuck..and a fairly decent aircompressor..and a vavle spring tool ment to b used while on the block still..not sure on the specificz of that engine but that is the general procedure for doin valve seals on pretty much ne engine..
Old May 14, 2007 | 07:31 PM
bad venge's Avatar
bad venge
Section Moderator
How many miles on the engine ???
Old May 14, 2007 | 07:43 PM
Nelson9937955
about 145,000
Old May 14, 2007 | 08:08 PM
bad venge's Avatar
bad venge
Section Moderator
With that many I'd really pull the heads and have the valve seats reground and do the entire head and replace the seals ...
doing them in the car won't help if you have bad valve seat sealing ...
