1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
95 starter fuse problem
Old May 15, 2007 | 03:06 AM
jethro's Avatar
jethro
Default 95 starter fuse problem
My friend has a 95 avenger v-6 and the starter fuse under the hood keeps blowing. Checked starter cable by pulling it off and nothing bare. Started once then on retry blew and ideas on what I am missing? My friends don't have alot of money to spend so trying to do it as cheap as possible.
Old May 15, 2007 | 03:27 PM
bad venge's Avatar
bad venge
Section Moderator
Default RE: 95 starter fuse problem
It might be a bad spot in the starter motor ... It hit once and was ok then it was on the bad spot and blew the fuse
Old May 19, 2007 | 01:34 AM
master tech's Avatar
master tech
Site Moderator & Tech
Replace the starter, the bendex drive is shorting the fuse out.
Old Jun 8, 2007 | 12:04 AM
jethro's Avatar
jethro
It blew on them while driving. Still possibly the starter?
Old Jun 8, 2007 | 12:14 AM
bad venge's Avatar
bad venge
Section Moderator
I doubt it blew while driving ... it's not getting any power when driving only when cranking ... It might have blew when it was last started ...
